Shift Kit for A4? Pros/cons
Old Jun 3, 2007 | 11:06 AM
ter's Avatar
ter
Default Shift Kit for A4? Pros/cons
I am having a problem with vibration from a torque converter. The manufacturer said it the torque management was wrong in the PCM, or the fluid was bad. So I am going to have that corrected. But he also mentioned a shift kit for boosting the tranny pressure to assure torque lock up. I would appreciate some comments on the shift kit issue. The only time I saw the kit discussed, people said they did not belong in a C5, because a good tuner is better than the shift kit. I thought it would be interesting to discuss. Maybe that is where I need to go. By the way, what is a typical price for the kit installed? Thanks.
