wiper won't shut off
Jun 3, 2007 | 03:32 PM
Wiper motor runs on low and will not shut off or change speed. It just randomly happened at 20K. Anyone else have this?? Any quick fix?? Thanx.
Jun 3, 2007 | 06:51 PM
St. Jude Donor '05-'06-'07-'08
I just had the same problem, my udders got clogged and killed my wiper motor. R&R of the wiper motor isn't that hard.
http://forums.corvetteforum.com/show....php?t=1715595
Jun 3, 2007 | 08:39 PM
appreciate it
instructions are great. mine does still work, just need to pull fuse to shut off...................
Jun 3, 2007 | 11:38 PM
Replace the control module on the wiper motor. (about $115.00 from GM) Also keep the udders clean.
Jun 4, 2007 | 04:41 AM
I got a rebuilt unit at the local parts place for about $45 with a lifetime guarantee.
Jun 4, 2007 | 07:46 PM
control stick
You don't think it could be the control stick in the steering column?::
Jun 4, 2007 | 08:24 PM
Quote:
Originally Posted by
leetownreb
I doubt it, EVERYONE that I have seen with the same symptoms (me included) had wiper motor issues.
Jun 4, 2007 | 08:59 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless it is obviously damaged (BROKEN) I doubt if the stalk is the issue. You most likely have clogged udders and a flooded module. Try cleaning the udders and letting the module dry out.
BC
Jun 4, 2007 | 10:25 PM
St. Jude Donor '08-'09
