Engine is knocking
Old Jun 4, 2007 | 02:27 AM
SunDevil C5's Avatar
SunDevil C5
Default Engine is knocking
I noticed quite a loud knock and ticking sound after I had taken a hard drive around. I'm not quite sure yet what or where exactly it is coming from. I know it is not the "sewing machine" noise and it was not making this noise prior. I believe I have it narrowed down to either piston slap or a stuck lifter. It is only present now on cold starts and will go away at full opp. temp. and when I accellerate and the rpm reach about 2-2.5 k. I've tried some lucas oil stabilyzer and that helped a bit but didn't elliminate the noise. I also noticed when adding the stabilyzer that I was almost a full quart low in only 1-2k miles since my last oil change. Any thoughts? Should I be worried?
Old Jun 4, 2007 | 02:41 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Normal on my 383 when cold. Goes away when op temp is reached.
Old Jun 4, 2007 | 04:00 PM
SunDevil C5
What causes it and how can I get rid of it?
Old Jun 6, 2007 | 08:35 PM
SunDevil C5
ttt
Old Jun 6, 2007 | 09:00 PM
T VETTE's Avatar
T VETTE
I was going to say piston slap but you said it was suddenly there. Maybe you didn't notice it before when cold and just now hear it.
Old Jun 6, 2007 | 11:19 PM
SunDevil C5
The noise started when the car wasn't even cold. It was at full opp. temp and stayed that way for awhile and then now only on cold starts.
Old Jun 7, 2007 | 04:47 PM
T VETTE's Avatar
T VETTE
Sure sounds like piston slap, normal condition for these, I would just drive it. Too much work to change pistons or rebuilt for a little noise when cold. This has been discussed before and the answer is usually drive it.
Old Jun 7, 2007 | 04:51 PM
SunDevil C5
My question is why such a change? Something usually causes it? Is there anything to help it?
To Engine is knocking
