Replacement shocks....
Old Jun 5, 2007 | 10:36 AM
lodilobo's Avatar
lodilobo
Default Replacement shocks....
My '99 frc w/ 38000 miles tends to wander slightly, so I am going to replace the shocks. Which ones are the best ? Are the Bilstein's on ebay good quality? Thanks.
Old Jun 5, 2007 | 11:38 AM
rws.1's Avatar
rws.1
the issue is more likely alignment than shocks...
Old Jun 5, 2007 | 11:59 AM
lodilobo's Avatar
lodilobo
You are probably right, but as long as I'm going over the suspension, are the shocks ready for replacement at 38k?
Old Jun 5, 2007 | 12:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I changed/replaced my 02 ZO6 shocks with C6 06 ZO6 shocks. There a direct bolt on replacement! I had a couple of people tell me that the ride is significantly better than my old shocks ( its a little firmer)
When I examined the old shocks (42,000 miles on them), they were still in very good condition! They still had a lot of dampening action and all the pressure.
I would have to agree with rws.1,,,your issue is most likely alignment.
BC
Old Jun 5, 2007 | 12:49 PM
LLVETTE's Avatar
LLVETTE
If you decide to go with new shocks, I highly recommend the Bilstein Sports. I was after a firm, responsive, performance type ride without going really harsh. I have read where others say the ride is too harsh with the Bilsteins, but I like it and my wife hasn't complained (she loves the car). I also autocross and participate in track days so I wanted a good performing system for both street and track. I got it with ZO6 springs, Hotchkiss bars and the Bilstein's. There are lots of choices and just as many opinions!
Old Jun 5, 2007 | 01:21 PM
HollywoodFRC's Avatar
HollywoodFRC
Default While you're at it - Aluminum Sway Bar End Links
I replaced the shocks on my '99 FRC with C6Z06 shocks and replaced the composite sway bar end links with 2004 C5Z06 aluminum sway bar end links. I really like the ride. No matter what you do as far as shocks go, replace the composite/plastic sway bar end links with the C5 aluminum ones.
Old Jun 5, 2007 | 01:38 PM
lodilobo's Avatar
lodilobo
Yes....I already have replaced the links..front and rear. Those plastic ones looked a little scarey when you took them off, didn't they? Thanks for the input...I'm ordering the Bilsteins.
To Replacement shocks....
