Front Lowering Bolt Question...
Old Jun 5, 2007 | 01:00 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default Front Lowering Bolt Question...
Is it possible to remove the front lowering/bushing bolts from your car without having to remove everything? Installing the front Z51 spring required moving the cailper out of the way, the steering rod and all kinds of other little things that equalled ALOT of work. Anyone have a better way?
Thanks,
Micah
Old Jun 5, 2007 | 01:07 PM
hotwheels57's Avatar
hotwheels57
Could you (carefully) cut the bolt and remove the two pieces? They're not available separately from GM though, so you might need them in the future.
Old Jun 5, 2007 | 01:21 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I have a set from my old springs, so cutting is an option.
Old Jun 5, 2007 | 01:29 PM
hotwheels57
I think I've read there are plastic threaded inserts in the springs, so a very clean cut/dressing should minimize any potential damage.
Old Jun 5, 2007 | 02:34 PM
VetteDrmr's Avatar
VetteDrmr
IIRC, you need to disconnect the lower shock mounts and the sway bar end link. At that point you should be able to support the spring and push the lower control arm down far enough to unscrew the adjuster.
HTH, and have a good one,
Mike
Old Jun 5, 2007 | 02:42 PM
WKMCD's Avatar
WKMCD
I replaced both of my springs this past weekend with Z06 springs. It took 2.5 hours from start to finish. Really pretty simple.
Old Jun 5, 2007 | 08:52 PM
JropTop's Avatar
JropTop
i DID MINE THE SAME WAY AS VETTEDRMER EXPLAINED,ITS REAL EASY!
Old Jun 5, 2007 | 11:21 PM
happa's Avatar
happa
Thanks ya'll, I think Im going to do it now cause the car is down. Thanks again for the helpful info!
Whats up Micah!
Old Jun 5, 2007 | 11:33 PM
minytrker's Avatar
minytrker
You can do it with just taking the wheel off. I have lowered 5 or 6 without taking them apart, but I did have 1 where the bolts wouldnt turn and I had to take everything apart.
Old Jun 6, 2007 | 08:19 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
May give it a shot this weekend or next. I will probably end up with a similiar case that the $%&*in bolt won't back out and I will have to remove everything.
Mike
Thanks for the info.
Originally Posted by happa
Whats up Micah!
Bryan, not much here, how are things there?
To Front Lowering Bolt Question...
