2002 LS6 air box cover
Old Oct 24, 2001 | 07:07 PM
chadwick's Avatar
chadwick
Default 2002 LS6 air box cover
Anyone dynoed this mod yet, especially on say a 2001 LS1 engine with no other mods? :D
Old Oct 25, 2001 | 02:50 PM
chadwick's Avatar
chadwick
Default Re: 2002 LS6 air box cover (chadwick)
ttt
Anyone? Anyone? Bueller?? :confused:
Old Oct 25, 2001 | 04:15 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
I've got one in transit now from Fichtner right now. I'll let you know how it feels, but may not dyno.
Old Oct 27, 2001 | 04:58 AM
maninblack's Avatar
maninblack
Default Re: 2002 LS6 air box cover (RedHot)
done it on my 02, great and easy mod,car still in break in period (800km) havent open it up yet but I have notice throttle respone is abit better :D
Old Oct 27, 2001 | 08:57 AM
AFVETTE's Avatar
AFVETTE
I added one to my 99 and felt a a surge over 4500 RPM's. I too am waiting for someone to have one dyno'd. Just one question if they do the dyno right after the install and don't do a computer re-learn I'm sure the numbers won't look much different. But after a 100 miles on my car I sure could feel the difference.
Tom
USAF Retired
Old Oct 27, 2001 | 09:01 AM
Richin Chicago's Avatar
Richin Chicago
I did it on my 2000 FRC..
It does seem stronger on the top end but don't have any data other than the seat of the pants. IT took me about 20 minutes as I had a minor skirmish with the PCV hose.
Old Oct 27, 2001 | 04:51 PM
silversport's Avatar
silversport
Default Re: 2002 LS6 air box cover (Richin Chicago)
awright, awright, I'm am obviously stupid but how do you get the airbox cover off??? Am I just babying it??? It seems that the rubber grommets at the bottom are right up against something metal so how do you pry this thing off???
I got the latches undone and I saw the old use the wrench from ur circular saw thing and tried that...wouldn't budge.
Suggestions??? Sheeeeeeeesh, how embeariskin.' :eek: :crazy: :cry :sad:
silversport
awright, awright, I'm obviously stupid but how do you get the airbox cover off??? Am I just babying it??? It seems that the rubber grommets at the bottom are right up against something metal so how do you pry this thing off???
Old Oct 27, 2001 | 06:59 PM
Jammon1's Avatar
Jammon1
Default Re: 2002 LS6 air box cover (silversport)
Unhook the latches, remove the filter and filter holder. Pop one side off at a time. They do take a little bit of effort. Reach down right next to the pins and pull/push towards the rear of the car. The rubber grommets may pull out when you remove the cover but they go back in without any problem. The new cover has the grommets already installed.
Just use your hands and a little steady gentle force will pop it off. Good Luck!
To 2002 LS6 air box cover
