Thermostat problem
Old Oct 24, 2001 | 07:14 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Thermostat problem
I have a 2001 Coupe. I installed Breathless Performances 172/178 Thermostat the other day. The problem is that the temperature has not gone down at all!!!
What is the deal?
Old Oct 24, 2001 | 07:20 PM
NetJunkie's Avatar
NetJunkie
Default Re: Thermostat problem (ICULUKN-C5)
Did you install a fan controller too? Need that for the fans to come on early.
Old Oct 24, 2001 | 07:21 PM
ICULUKN-C5's Avatar
ICULUKN-C5
No, did not install a fan controller. Where can I get this?
Old Oct 24, 2001 | 08:46 PM
kendawg's Avatar
kendawg
Wrong:I added a .12 spacer at the bottom of my stock thermostat,i run at 178/176 on the freeway,with NO fans on,take the stock thermostat apart an add a spacer were the plunger bottoms out.
I have my vinci fan controller to turn on at 185,because it dosent matter what thermostat you have, when your siten in a drive thru,or long light, your temp well rise tell the fans turn on/
194 seems to be the highest mine goes too
69.00 for a thermostat an some dont work,this mod on the stock thermostat works/by the way if you add like a .06/.09 shim you run at 181/183
http://andrewb.speedware.com/thermo/thermo.htm
[Modified by kendawg, 6:54 PM 10/24/2001]
To Thermostat problem
