Driving without sway bar ?
Old Jun 5, 2007 | 01:22 PM
jor8888's Avatar
jor8888
Default Driving without sway bar ?
something is making squeeking noise and I took out the sway bar bushings and grease them but still getting same noise. Is it ok to drive the car without the bushings just to see if the noise is from the bushings? thx.
Old Jun 5, 2007 | 01:29 PM
FRCTony's Avatar
FRCTony
Sure, just take it easy.
Old Jun 5, 2007 | 01:30 PM
AU N EGL's Avatar
AU N EGL
Dont drive hard or fast. hard corning with out a swaybar attach could put you into a spin or into a wall
Old Jun 5, 2007 | 05:17 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Just dont make any turns and drive stright You will be ok if you take it easy in turns.
Old Jun 5, 2007 | 05:37 PM
2079's Avatar
2079
Man just spray silicone oil on them that should stop them from squeeking if thats the problem area ...then take it from there...
Just my 2 penny
Old Jun 5, 2007 | 06:43 PM
OMG its Jason's Avatar
OMG its Jason
On my 00 Trans am I had I didn't have the rear swaybar on and it drove fine. Had a little more body roll on the turns, but helped getting traction on launches.
I am not sure at all if it's similar to our C5's as I am still learning about these every day.
Old Jun 5, 2007 | 07:23 PM
jor8888's Avatar
jor8888
I am just going to take out the bushings and drive it up and down the driveway to see if it squeeks.
Old Jun 5, 2007 | 10:25 PM
SpeedyD's Avatar
SpeedyD
So you're still leaving the bar in, just taking the bushings?? You might get rid of the sqeak but you will surely hear the clunk! It won't hurt anything but the bar will eb bouncing around. If you are talking about removing the hwoel bar, you will be fine. The sway bar ades in stabilizing the car in the corners.
To Driving without sway bar ?
