Where does this harness go...
Jun 6, 2007 | 11:25 AM
Theres a wire/harness set on the passenger side of the car that comes off the fuse box and down under the car, theres an open (not connected to anything) female connector midway through then it continues to the underside of the car. I only ask because its partially melted onto my longtubes.
Jun 6, 2007 | 11:37 AM
Jun 6, 2007 | 12:09 PM
A little hard to see as its so cramped down there.
Jun 6, 2007 | 12:14 PM
Do your headers have an off-road X pipe?
It looks like the connector for the rear O2 sensor...
Which you would not be using...
Jun 6, 2007 | 12:15 PM
Hey OutKlast... update your profile.. it says you don't have a Vette yet....
Jun 6, 2007 | 12:36 PM
Quote:
Originally Posted by
rws.1
Ahh makes sense, yea no cats offroad X-pipe. Why does it keep going down under the car? Does it connect to something else as well?
Jun 6, 2007 | 01:05 PM
its an O2 sensor connector
Jun 6, 2007 | 01:10 PM
It is clip fit in behind the heat shield and some people install it above the tunnel plate, so I suspect someone just did not bother to take the time to remove it....
