19" Wheels all around - Problems???
Old Jun 6, 2007 | 12:01 PM
LeMansBlue04's Avatar
LeMansBlue04
Default 19" Wheels all around - Problems???
I have a friend who has a set of CCW 505a's he wants to sell me. They have been through at least 3 owners and he says thay need a polish. Ok, I have no problem with that but.... the fronts are 19x9.5 and the rears are 19x11. The tires are Pirelli P Zeros.
What I am wondering is this. Will 19" wheels all around the car be a problem???
Old Jun 6, 2007 | 12:15 PM
Wah's Avatar
Wah
They should not be a problem. I run 18x10.5 all around. Same size tires even. You just need to get properly sized tires, that's all.
Old Jun 6, 2007 | 12:51 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
The largest problem is tire choice.The 19 all around setup is fine,but your tire options are a bit limited
However,you can still find them
I run 295/35/19 rears( Most run 30 series in the rear as the 35 series is impossible to find now)and 275 /30/19 fronts
No problems with either of these setups,as long as you are minimally 295/30 rear and 275/30 front,you are good to go
Old Jun 6, 2007 | 01:21 PM
STLKillerC5's Avatar
STLKillerC5
It's not a problem. CCW sells a lot of 19" all the way around packages. Just make sure your tires are sized right in order for the traction conrol system to recognize the front and back. The back needs to be taller. CCWs are sweet! Get them!
Old Jun 6, 2007 | 01:46 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
I run 245/35-19 front and 275/35-19 rears
Old Jun 6, 2007 | 02:12 PM
waupachino's Avatar
waupachino
I am running 305/30/19 rears and 275/30/19 fronts. No problems at all.
Old Jun 6, 2007 | 02:33 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
no issues, I have the same sizes.
Old Jun 6, 2007 | 02:41 PM
SLO C5's Avatar
SLO C5
From: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
19s all around look nasty.
I've got 19x10 and 19x13 505As with 275/30 19 and 345/30 19 Pilot Sports. I still need to do a little more tub work, but the new shoes totally changed the look of the car.
Old Jun 6, 2007 | 02:48 PM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
Send Me some PICS!!!!!!
Old Jun 6, 2007 | 07:19 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
19's all the way around here...no problems!!
Old Jun 6, 2007 | 07:37 PM
LeMansBlue04
Thanks guys I really do appreciate the help. The possibility of running larger rotors will be nice too.
Old Jun 6, 2007 | 08:18 PM
jtkeller's Avatar
jtkeller
St. Jude Donor '07
I've been considering CCW SP500's and have seen a lot of 18/19 and 19/19 combos. Is one package preferred over the other? I'd assume the 18" fronts would be easier to find tires for. Is there any particular reason to choose one over another?
Old Jun 6, 2007 | 10:20 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
no issues...
Old Jun 7, 2007 | 11:16 AM
LeMansBlue04
Originally Posted by Ikester
no issues...
Wow!!
What do you use to keep those wheels polished?
Old Jun 7, 2007 | 12:45 PM
waupachino's Avatar
waupachino
19/19 all around look awesome, but 18/19 you have more tire choices and save some money.
Old Jun 7, 2007 | 02:59 PM
romeokc10's Avatar
romeokc10
I run 19's front 275/40/19 and 20's 305/25/20 rear, you don't want to lose that raked look!
Old Jun 7, 2007 | 04:37 PM
flynbya2's Avatar
flynbya2
Pics please!!!
To 19" Wheels all around - Problems???
Old Jun 7, 2007 | 05:01 PM
azmusclecar's Avatar
azmusclecar
I thought the active handling would throw codes if you didn't have a difference in front to rear diameters.............or am I late to the party here?
Old Jun 7, 2007 | 05:34 PM
flynbya2's Avatar
flynbya2
You are correct,however the tire sizes posted above have enough stagger that it does not trip anything
Old Jun 7, 2007 | 05:49 PM
azmusclecar
See the first quote? This is what I was referring to........it says "same size tires even"
I thought the word "same" meant: identical, unchanging, unvarying, not different
but what do I know???????????????????????????
