Here we go again!!!
Old Jun 6, 2007 | 07:54 PM
98 C-5's Avatar
98 C-5
Default Here we go again!!!
Well, took the 5 to the dealer today with a harness K problem (in hand). This harness k has been removed from the vehicle and drives great! Install it you get the old wait ten seconds pull key, but get this, the dealer informed me that it's best not to install a second harness K... that I would have this problem again. Is this true? Has anyone experienced this? Have read several posts but what ?????????????:
Old Jun 6, 2007 | 08:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Recommend that you call the GM Custormer Service Center and file a complaint with them. They will contact the dealer and that should get some sort of answer. At least you will have a file number and a case#
BC
Old Jun 6, 2007 | 08:15 PM
happa's Avatar
happa
BC
Good Luck!
98 C-5's Avatar
98 C-5
I've got a case # GM sent me to this dealer.
Old Jun 6, 2007 | 08:27 PM
98 C-5's Avatar
98 C-5
Is it safe to drive?????
Old Jun 7, 2007 | 11:23 AM
jovette's Avatar
jovette
Yes, it is safe to drive. Suggest you forget about getting another dealer / GM supplied K-Harness. Instead I strongly recommend you do like most others here on the forum, order a CLB unit from Corvettes of Houston or Thunder Racing, about $50 and install the CLB and be done with your Column Lock problems. That's what I did when my dealer installed K-Harness failed last year. No problems since I installed the CLB.
Old Jun 7, 2007 | 11:45 AM
sliebl's Avatar
sliebl
Do the CLB and be done with the K-Harness wowes.
Old Jun 8, 2007 | 04:54 PM
98 C-5's Avatar
98 C-5
Thanks!!!!!!
To Here we go again!!!
