Manual Trans drain plug
Old Jun 6, 2007 | 09:46 PM
jbone's Avatar
jbone
Default Manual Trans drain plug
Yeah does anyone have a link with a picture of where the manual trans drain plug is? Is the filler plug and drain plug the same?
Old Jun 6, 2007 | 11:14 PM
jbone's Avatar
jbone
Old Jun 6, 2007 | 11:40 PM
jbone's Avatar
jbone
Anybody?
Old Jun 7, 2007 | 01:14 AM
rws.1's Avatar
rws.1
two different plugs. Drain is on the bottom stamped Drain above and to the right.... It requires a large allen key (10mm?) to remove it
fill is on the side the case is stamped drain to the left of it... it should have a metal tag on it saying Dexron III. This can be removed with a 1/2 extension on a ratchet.
the torque for both is 20 ft-lbs.
Old Jun 7, 2007 | 01:22 AM
jbone's Avatar
jbone
Thanks for all your help RWS. Your the only one who knows anything around here
To Manual Trans drain plug
