cleaning motor
Old Jun 8, 2007 | 11:30 AM
pfmvette's Avatar
pfmvette
Default cleaning motor
whats the best stuff to use to keep the motor as clean as it was when i bought it???
Old Jun 8, 2007 | 11:59 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I use Simple Green, paintbrush and spray bottle of water (when engine is cold)
I have a kettle steamer also that really peels off anything.
Use my compressor at 65 psi for just dust.
Old Jun 8, 2007 | 12:31 PM
goatts's Avatar
goatts
I use protectant on vinyl and rubber. I wipe down the other parts with interior detailer. I use a paint brush in hard to reach areas. Simple Green is a strong solvent so I use it only when necessary. Most engine manufacturers recommend that you NOT spray large amounts of water on the engine (garden hose for example).
Old Jun 8, 2007 | 04:04 PM
clutchman's Avatar
clutchman
This works awesome, once you get over the initial shock.
Warm the engine (not hot) and cover any items like open air cleaners. Spray down the entire engine and trim, everything with Windex. I mean wet. Close the hood.
(At this point the instructions I had say to )
Come back in 30 minutes, hose it all off. While its wet, spray it down with armor all or similar. Again, I mean wet. Close the hood and wash the car.
When you open it back up after washing, you won't believe your eyes. Just dab any pooling of armor all and viola!
Old Jun 8, 2007 | 09:23 PM
Blown 346's Avatar
Blown 346
I do the same thing and have great results everytime, the engine bay looks brand new.
Old Jun 8, 2007 | 10:56 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I'm a bit intimidated by the electronics in our bay. So I've been searching for an alternative to all the water. I 've been using no touch foaming tire cleaner on all the surfaces under the hood. It cleans well and leaves a nice sheen on the plastic and rubber without attracting dirt. It also seems to bring the aluminum parts back to a like new look and protects against future oxidation. Of course if you've got REAL dirt, a stiff parts cleaning brush might be in order.
Old Jun 8, 2007 | 11:17 PM
BATM4N's Avatar
BATM4N
Are you turning off the car at or after you "Come back in 30 minutes"???
Old Jun 8, 2007 | 11:26 PM
Bill Dearborn's Avatar
Bill Dearborn
I use a 50/50 mix of Simple Green and Water in a spray bottle to soak the engine when it is cold. Then I let it sit for 15 to 20 minutes and wash down with the hose. Then I close the hood and start the engine and let it idle for 20 minutes. This drys everything nicely.
Bill
Old Jun 9, 2007 | 07:01 AM
clutchman's Avatar
clutchman
turn it off after warming it up
Old Jun 9, 2007 | 06:00 PM
Garibaldi's Avatar
Garibaldi
EXCEPT: I leave the engine running while I spray it down, the combination of the warm engine and Corvette mojo keeps the the electrons flowing in the correct direction. When I'm done with this step, I let it run a little more and shut it down. When it's time to rinse it off, I start the motor, make sure the electrons are facing in the correct direction and spray like there's no tomorrow. Seems to work for me. Stop spraying, let it idle, shut 'er down and wipe all the water off. Spray with vast quantities of your favor "Whoa! Is that a shiny radiator hose or what?" spray. Wipe once more. Go out and impress your [guy] friends. Never met a woman who gave two sh**s about a clean engine.
GP
To cleaning motor
