Fog Light cable wire
Old Jun 8, 2007 | 10:10 PM
george's2001c5's Avatar
george's2001c5
Default Fog Light cable wire
How far does the cable for the fog lights on a 2001 come up after it is removed from the bulb. Will it come up high enough to go above the open headlights. Because if it don't I guess you pull it off the bulb and do the bulb and than reattach. Mine is burned out. I can get my arm down but I am trying to make it as easy as possible. Thanks for your help.
Old Jun 9, 2007 | 07:53 AM
Pres712's Avatar
Pres712
Default Not sure
I've replaced the bulbs in mine with the brighter 55 watters. I'm 6'2" - 250 lbs. and not made with small arms but was able to reach down after taking the bezel off the headlights. Rather than listen to the dinging of the warning, I hand screwed the lights in the up position to work on the fogs. Just a simple half turn and they are out. Good luck!!
