Outside temp pigtail connector
Old Jun 9, 2007 | 06:17 PM
jjmoberg's Avatar
jjmoberg
Default Outside temp pigtail connector
Can this part be ordered? I replaced my sensor due to the readout of 69 degrees. However, the prongs from the old sensor had corroded completely off and were stuck in the connector. I had to cut the connector out, cut it open with a dremel, and then splice it back in. Needless to say it still does not work. I need a new connector I can properly solder in, shrink wrap, etc. Would Gene have such an item? Still reads out 69 degrees after miles of driving and multiple days since replacement.
Thanks,
Jeremy
Old Jun 9, 2007 | 09:49 PM
gpracer1's Avatar
gpracer1
Had the same problem on my 00. Temp sensor $12 bucks. The pigtail cost $33
