Run Flats Or Regular Tires
Old Jun 10, 2007 | 11:14 AM
JOEY P's Avatar
JOEY P
Default Run Flats Or Regular Tires
What rides better
Old Jun 10, 2007 | 11:40 AM
IFLUBYU's Avatar
IFLUBYU
No question the ride is better on almost anything non-runflat. Unless you are one to continuously worry about a flat, heh...
Put a can of fix a flat in the back, get some decent tires.
Only use the fix-a-flat if you have no choice as it will cost you extra for the tire swap and a new pressure sensor.
Good Luck!
Old Jun 10, 2007 | 11:44 AM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
Old Jun 10, 2007 | 04:28 PM
rgtkst's Avatar
rgtkst
x 2
most leaks are slow ones so the fix a flat is a not too often used thing
Old Jun 10, 2007 | 06:53 PM
tudac3-5-6's Avatar
tudac3-5-6
Default USE runflats
When you put "fix" chemicals into the C5 and C6 tires/wheels, you will also get the chemical onto the pressure sensor. That will show incorrect pressure on the LED reading. Then you will have to take your car to a tire dealer or Chevy dealer to get the pressure sensor to be replaced!
That will cost you more money in the future!
In other words, USE runflats!
Old Jun 10, 2007 | 11:11 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Get rid of the runflats, you will be very happy.
Old Jun 11, 2007 | 07:32 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Non Runflats will ride quite a bit softer HOWEVER ....
Old Jun 11, 2007 | 07:37 AM
vettenuts's Avatar
vettenuts
I put on the non-runflat Goodyear GS-D3's. The difference is nothing short of astounding. No more skipping over bumps, they ride better, they are quieter and they have much better traction. I carry a small Mercedes jack, tire plugs and a small pump when I go on a trip. Ultimately, the decision is yours but I noticed the tires in the first 50 feet they were on the car the difference was so great.
Old Jun 11, 2007 | 07:41 AM
B-Vette's Avatar
B-Vette
There's always a trade off, wheather it's horsepower vs. fuel economy or quality of ride vs. piece of mind when it comes down to tires. Your going to get a lot of pros and cons on this topic.
Old Jun 11, 2007 | 09:59 AM
rws.1's Avatar
rws.1
runflats = security and peace of mine
non runflats = performance and ride
Old Jun 11, 2007 | 12:05 PM
99 vett babycar's Avatar
99 vett babycar
Good Luck!
Old Jun 11, 2007 | 12:09 PM
R Devil's Avatar
R Devil
Old Jul 7, 2007 | 04:43 AM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
I am new to the forum here, this my first post. I am currently in Iraq and I have a machine silver 2004 coupe at the house. In my spare time I have been reseaching various aspects of Corvette maintenance, performance, etc...
I have had my current Vette for about 3 months before I left, and I must say, I don't get the "harsh ride" and "run crap" comments about the OEM tires. I never detected those characteristics. My Vette rides as smooth as Cadillac so far. Granted, I don't street race or drive competitvely, but other than cost, I don't see anything wrong with the OEM tires.
Old Jul 7, 2007 | 09:46 AM
csexton's Avatar
csexton
Took off my run flats and switched to KDW II and couldn't be happier
Chuck
Old Jul 7, 2007 | 02:31 PM
white90conv's Avatar
white90conv
This is my view. My c5 with run flats has an overwhelmingly better ride than my '90 c4 with regular tires. However, I believe the people who say the ride is much better on the c5 without the runflats. I am still not sure what tire I will get.
Old Jul 7, 2007 | 02:39 PM
KidCid's Avatar
KidCid
CI 7-8 Veteran
I didn't either but I recognize the collective wisdom of this bunch and switched to non-run flats when I got my new wheels. The difference in ride and handling is nothing short of amazing. Even my (all cars annoyances that I must use to get from point A to point B) wife immediately noticed the difference. All I can say is that when you get back, try and find a ride with someone that has non-runflats and do a comparison.
BTW, I'm assuming you're in the military. Thanks for your service.
Old Jul 7, 2007 | 02:44 PM
1FASTVERT's Avatar
1FASTVERT
St. Jude Donor '12
Good Luck!
I am going with the sumitomo's. Cheap and a good ride.
Old Jul 7, 2007 | 11:35 PM
Bluemill's Avatar
Bluemill
Default Pirelli P Zero-Nero
The difference in ride and howling tire noise between the old Goodyear runflats and my new Pirellis is huge. The old tires were like trying to play basketball with dress shoes on while the P-Zero's are like high tech sneakers! Very quiet too. The biggest improvement I've made to the car - by far.
Old Jul 8, 2007 | 12:46 AM
waterzap's Avatar
waterzap
Instead of Fix a Flat, have a look at the slime kits. Costs about $20, which includes the sealant and a little compressor. Similar to the Z06 kit I think, except for the price.
http://www.slimesealant.com/
Stuff seems to be water soluble, so might or might not hurt the sensors. On the other hand, a set of non run flats is about the same price as two runflats..maybe even less. So you can buy a lot of sensors for the difference in price. Just bought a set of Cooper Zeon Sports. W Rated so no problem with speed, and a 400 thread life, so should last at least as long and probably quite a bit longer than the Goodyears
The difference is like day and night. Instead of hearing the tires on the road, I can now hear the (stock) exhaust. Definitely more of a GT car now.
To Run Flats Or Regular Tires
