there was a small patch of petrol on the garage floor under the engine, started engine and car was missing a bit , drove it and it was worse under accelleration (missing badly) then came right. Hour later started engine again (strong smell of petrol in car) and the same happened, have had codes PO200 and C1214. hope its not terminal
28-TCS - Traction Control System
C1214 Sol Valve Relay Contact or Coil CKT Open
I don't think that has anything to do with your leaking fuel issue though.
I couldn't find one for P0200, did you get that one right? Here are the ones around it...
P0175 Fuel Trim System Rich Bank 2
P0230 Fuel Pump Control Circuit
P0300 Engine Misfire Detected
Where is the fuel leak exactly under your engine? Might be able to pinpoint the problem that way and get it reconnected (if it's that simple). Hopefully someone will chime in that had a similar issue.
re C1214
yes, its happened twice in the last 2 months.
If the gizmo is u/s...... what does u/s mean?
It could be incipient problems with the EBCM. Mine started like that and I ended up having to have it replaced. absfixer.com does a repair if it gets worse.
