Rear Diff Goes Boom!!!!
Old Jun 11, 2007 | 09:14 PM
02402ramair's Avatar
02402ramair
Default Rear Diff Goes Boom!!!!
I was on the long haul power tour 1/4 mile from the last stop ( little rock, AR fair grounds) and I was driving on some rough bumpy pavement when I dropped a gear and stood on it, the car started to wheel hop and before I could get out of it, BOOM
Here are the results.
Old Jun 11, 2007 | 09:16 PM
02402ramair
Old Jun 11, 2007 | 09:18 PM
02402ramair
Who has the best prices on rear diff parts?
Old Jun 11, 2007 | 09:32 PM
TYSON1997's Avatar
TYSON1997
I would guess it would be cheaper to buy a whole new diff thats already built. Obviously oe stuffs not gonna hold up to it. Thats a pretty good break though.
Old Jun 11, 2007 | 10:21 PM
02402ramair
Any recommendations on a new diff
Old Jun 11, 2007 | 10:38 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
DTE
But he will be the first to tell you that no rear end is bullet proof.
http://www.dynotech-eng.com/
Old Jun 11, 2007 | 11:28 PM
2004SpiralGrey's Avatar
2004SpiralGrey
I was going to try and go with the Quaife Differential when I got some money together. They retail for about $1700. Do a google search also you can PM CF forum member- "jbsblownc5" about the Quaife.
Old Jun 12, 2007 | 12:01 AM
BanditDude's Avatar
BanditDude
Originally Posted by Threed
DTE
But...their cast iron diff must be close to market by now.
Old Jun 12, 2007 | 05:26 AM
vettenuts's Avatar
vettenuts
DTE
They also have warnings in very large bold print that if you wheel hop even their rear, all bets are off and no warranty. I don't think anyone will for that matter.
Old Jun 12, 2007 | 07:03 AM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
That is correct.
If anyone puts there car through wheel-hop abuse and they break our products in the process, they are on their own and the driveline won't survive for long- even with the heaviest duty parts, as wheel-hop is that destructive....
Wheel-hop *IS* avoidable and controllable 100% of the time *IF* the user is so inclined to take the necessary steps to make it happen. Most don't....
Old Jun 12, 2007 | 11:26 AM
Hardtop01's Avatar
Hardtop01
Originally Posted by DynoTech Engineering
That is correct.
True. If it hops you better be let off the gas. How can you tell if one of your rears has had damage from wheel hop.
Bruce
Old Jun 12, 2007 | 12:31 PM
VLVETTE's Avatar
VLVETTE
Try Fitchner the going rate on a new Z06 3.42 pumpkin is around $1100.00 .
Old Jun 12, 2007 | 03:57 PM
02402ramair
I bought a new 3.42 Z06 rear diff for 1063.56 from gm parts direct.
The good thing about this unit is that it is all new. I will be putting the new 300mm long shaft I already have in this new unit.
Thanks for the help guys.
Old Jun 12, 2007 | 04:21 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
That is correct.
Impressive blow-up....not much left useful in that unit
Phil has a good product, not to mention excellent customer service. He can build you a rear a bulletproof as you would like to spend (various "levels").
Speaking of DTE products, whats the latest on the cast iron case Phil??
Havent seen or heard much about it since the tradeshows....
Regards,
Tony
Old Jun 13, 2007 | 10:11 PM
02402ramair
I bought a NEW Z06 3.42 rear diff and replaced the long shaft with a 300mm shaft. GM has a 12/12 warranty on there diffs.
Thanks for all the input and help on this issue guys.
Problem is solved for now.
Old Jun 14, 2007 | 05:50 AM
vettenuts's Avatar
vettenuts
Does it normally wheel hop or was this simply the result of the bad pavement you were on? If you get this all the time, DTE has a list of recommended suspension upgrades that will help eliminate it.
Old Jun 14, 2007 | 08:53 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
By yourself a DTE Brace, it might have saved ya.
To Rear Diff Goes Boom!!!!
