clutch help.
Old Jun 12, 2007 | 12:24 PM
yodas little brother's Avatar
Cruising
Default clutch help.
is there any tricks to doing a clutch.gm wants $200 for the service manual.email me with any info rodonous@yahoo.com thanks a bunch
Old Jun 12, 2007 | 01:01 PM
95BlueBomber's Avatar
95BlueBomber
There is online directions on doing this. If you have a lift it is very easy. I have done a few and they get easier everytime. Search for Dope clutch install. I believe that will get you where you need to be.
Old Jun 12, 2007 | 01:03 PM
95BlueBomber
http://www.cajundude.com/c5techhome.htm
There ya go!
Old Jun 12, 2007 | 06:51 PM
vettenuts's Avatar
vettenuts
I just did mine. Took my time and planned ahead for it. Its not hard, its just a lot of work but I feel pretty good getting it done. I started with some of the on line instructions and then modified them to suit my procedures and intermixed in the service manual as well. There are several gotcha's along the way that the service manual helps with. Also, if you contact Gene Culley, you can get the service manual a lot cheaper, just over $100.
Old Jun 13, 2007 | 11:48 AM
Cruising
thanks alot peoples
To clutch help.
