Anyone switched to 7.425 pushrods after installing the Cadillac Racing Lifters? If so did this lenght pushrod help quiet the valve traing down? Thanks,
SLPRC5
from what i have seen, the caddy lifters do like a little longer pushrod. I used a 7.425 once and it did quiet the valvetrain down. did you mill the heads any when you had them off? It seems that taking about .010" off the head (if it hasnt been milled yet) helps a lot too
Great to hear (no pon intended).
The heads are Patriots 243s and had the cc mill from 64cc to 62cc.
Well I don't plan to remove the heads. So I'm going with the 7.425 push rods to quiet down the VT more than it is now...everyone was saying how the Caddy lifters made the VT quieter, but no one mentioned the push rod lenghts..
Thanks Quick
The longer pushrods will quiet it down no matter what lifters you have. I just don't understand why so many people still say to use the stock length pushrods when a bigger can is used. After I seen for myself that the the aftermarket cams have a smaller base circle it just made total sense that a longer pushrod needs to be used to get back to the correct preload. Deno, I bet you will be happy with the way it will sound after you get the pushrods in. Like i said if you need any help just call me.
Hey Marc I'm glad you put this out there..now maybe others will understand the need for the longer push rods. I have a set ordered and plan to install them sometime next weekend.
I'll let you know how it works out and make a sound clip on the new push rods
Thanks Buddy,
Deno
Cause not ALL aftermarket cams run a smaller base circle.. Also, there is no set base circle size. Some companies run different sizes. You need to know the measurements in order to properly determine what you need.
The reason people "Chase" valvetrain noise is because they dont want to spend 20 bucks to buy the proper tool necessary in order to verify the size requirements.
Originally Posted by mvvette97
I just don't understand why so many people still say to use the stock length pushrods when a bigger can is used. After I seen for myself that the the aftermarket cams have a smaller base circle it just made total sense that a longer pushrod needs to be used to get back to the correct preload. .
Unless you measure you are just guessing and wasting money.
I just installed the 7.4s that LGM supplied w/ my kit, stock are actually 7.38X. All is well on my end, but if I ever pull the heads I'll be installing the caddy lifters and measuring for correct pushrod length.
you are right. There is no way though that you can get it exact when pushrod sizes are in .025 increments. Example on mine is that I need a 7.440 to get me back the the stock preload. I have to run the 7.425 because the next size up is the 7.450. I believe that too much preload will do more damage than not enough. So in reality there is no way to get it perfect but you can get it close as long as you know the measurements of your cam.
How do you measure? I just did partiot stage 2 heads with stock lifters and a 224/224 cam. I used 7.400 rods....will that be ok?????????
You may have the same problem I'm having with the sewing machine sound.
I have the Comp Cam 224/224 .567/.567 on a LSA114.
I have cadillac racing lifters and at present 7.400 PR, so I have the 7.425 ordered and like others have said this should quieten it down, if not I'll have to live with it because the engine is all together now.
Very good point, besides you have heard the difference between the 7.400 and the 7.425 PRs.
How is your valve train noise? vettenuts told me you have gone with yella terras rockers and it helped quiet your VT noise. If the 7.425 push rods doesn't quieten it I'll try the rocker install.
Thanks,
Sleeper
^ I have yella terras... they're the newer lightened design. They work great. There is valvetrain noise when the oil is not, but nothing worse than stock when hot. Click the link in my sig for an idle video. I don't run fuel rail covers and I have a vented hood so that actually increases the noise.
Are you sure about the stock length you're quoting? I measured mine with a caliper and they were 7.400" stock.
You can't measure length with a caliper and determine the pushrod length. This is because the actual pushrod length used by the manufacturers and printed on the pushrod is "gauge" length, which is determined from a fixed diameter on the ball end of the pushrod (typically where the ball is 0.140" diameter). Thus, if you measured 7.400" with a caliper the actual gauge length is about 0.017" shorter (this is an approximation) or the 7.385" quoted above. The adjustable pushrod you buy to measure length has a preset closed length and then every turn of the pushrod open adds 0.050" to the length. However, the length being measured is gauge length which is then what you buy. For example, if you have the Comp adjustable, the closed length is 6.800". Lets say you measure and find that it takes 10.5 turns to adjust the pushrod to get zero lash. You would add this onto the closed length:
6.800 + 10.5 X 0.050 = 7.325"
However, now you must add in your lifter preload to set the plunger in the lifter. If you want the preload to be 0.100", you would add that on and end up with 7.425" pushrods.
