cooling down
Old Jun 12, 2007 | 08:04 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default cooling down
I've noticed my car (97 coupe) and my mom's (98 vert) both hover around the 200 deg range once warmed up. Everything in the cooling system is stock and the Radiators are free of debris.
a) is this a healthy temp for regular road driving
b) what ways would you suggest to get the running temp down to say 170-180 area?
Old Jun 12, 2007 | 08:08 PM
bustin knuckles's Avatar
bustin knuckles
From: Sounds like a T Rex lives under my hood. Gibsonton, Fl
winter seriously ,cleaning radiator fins installing 160 therm and resetting cooling fan cut in temp. 185 is a good operating temp.
Old Jun 12, 2007 | 09:12 PM
65GGvert's Avatar
65GGvert
If it ain't broke, don't fix it. That's what it's supposed to do.
Old Jun 12, 2007 | 09:41 PM
csexton's Avatar
csexton
Car was designed to run between 195 and 200.
Chuck
Old Jun 13, 2007 | 12:19 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
if the car was designed to run at that temperature, what is the point of an aftermarket low temp thermostat?
Old Jun 13, 2007 | 12:44 AM
Sky King's Avatar
Sky King
Interesting you should bring this up... I've noticed my '98 coupe is running coolant temps of 196*to 201* lately now that we have warmer temps here in Illinois. Seems like it was more in the area of 187* or so in cooler weather this winter. Guess this is all perfectly normal?
Old Jun 13, 2007 | 06:54 AM
bustin knuckles
One design, different climates.Sitting in traffic in S Fl is killer.
Old Jun 13, 2007 | 07:06 AM
65GGvert's Avatar
65GGvert
What does aftermarket anything have to do with design of the car. The car was designed to run at 200 degrees, if you want less, feel free, but it has nothing to do with the design.
Old Jun 13, 2007 | 07:16 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The point is to prey on the minds of the paranoid people who think there car needs to run below 170 degrees lest it blow up.
Old Jun 13, 2007 | 10:50 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Car was designed and programmed to run hotter than you would think. You actually want your oil temps in the 200 range or a bit more. Coolant temps, you can get up to 225 in stop and go traffic before your second fan kicks on..again, that is normal for these cars (stock) and it won't hurt anything.
It is good to check the radiator area, and AC condensor area to make sure they are clear, since the car is low, they tend to suck up lots of junk. Seen it happen before.
Old Jun 13, 2007 | 01:30 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Actually the first fan is programmed to come on at 226 degrees (stock)
Old Jun 13, 2007 | 02:15 PM
MattB's Avatar
MattB
To make money.
Old Jun 13, 2007 | 03:28 PM
DPG's Avatar
DPG
St. Jude Donor '06
Originally Posted by MattB
To make money.
nice avatar btw i love that show
Old Jun 13, 2007 | 04:06 PM
davidfarmer's Avatar
davidfarmer
emmissions requirements give us the high temps, engine runs cleaner up there. Cooler thermostat will give a bit more power, and let you run a bit longer at the track before over heating, but nothing is wrong with 200deg temps
Old Jun 13, 2007 | 04:12 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
The LS based motor was designed (and runs optimum) at 195-198*. Lower temps can actually cause premature engine wear. 200* is MORE than fine.
My goal when I am putting together my cooling system, is to hover between 187-205(depending on seasons)
I know the data (and my goals) contradicts what I originally said, but I do it to aid in keeping my underhood temps down.
Old Jun 13, 2007 | 05:14 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I suppose the low temp thermostats/heavy duty radiators and electric water pumps are for those that spend a lot of time at the track. It makes more sense because track driving would put alot more stress on the engine creating consistantly higher temperatures.
Houston summer had me worried but if the car was designed to run in that temp range I guess i have nothing to worry about.
To cooling down
