Engine cradle noise???
Old Jun 13, 2007 | 02:53 PM
wwnf's Avatar
wwnf
Default Engine cradle noise???
I just recently purchased a 1998 vette with 13K miles. There's a popping noise in the front somewhere and sometimes you can feel it in the floor. Happens mostly during turning around in a driveway that's not level. Have heard it going slow around turns with a decent.
I had my mechanic check it all out and can't find anything in the front suspension or steering.
I have a feeling it's the engine cradle. I had the same problem with my 2000 impala and they installed shims and the problem went away.
Anybody have any ideas?
Joe
Old Jun 13, 2007 | 03:39 PM
davidfarmer's Avatar
davidfarmer
Check the large 21mm nuts holding it to the frame. They do work loose occasionally. I don't think shimming would be necessary, but it could be loose.
Old Jun 13, 2007 | 09:29 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
I had a bad front Hub make alot of noise on my car.
Old Jun 18, 2007 | 04:13 PM
wwnf's Avatar
wwnf
I torqued all 4 of the cradle to body bolts, I think there's 4. Didn't change anything with the noise. This is my first vette and I'm not sure what that composite bar thing that's on the cradle that looks like it's pushing down on the lower control arm. What's that called? So I can search. Can it make noise?
Old Jun 18, 2007 | 04:31 PM
timemender's Avatar
timemender
That composite (long transverse) bar that spans the car from side to side (front & rear) is the fiberglass spring.
Word of caution; NEVER clean the fiberglass spring with any type of solvent such as paint remover, etc. It will cause the spring to delaminate and fail. It may take several weeks or months after exposure, but it will fail.
Old Jun 18, 2007 | 06:37 PM
double-oh-coupe's Avatar
double-oh-coupe
I'm having the EXACT same problems. I've been through the front end twice and can't find anything. I'm wondering if maybe a shock in going back -- although if that were to happen I don't know if I'd feel it in the floorboard. This one is frustrating me ...
Old Jul 9, 2007 | 02:00 PM
mike.e.harris's Avatar
mike.e.harris
8th Gear
Default Popping noise in front end.
I'm having the same problem on my 98. I'm convinced it's either the lower a-arm bushings or the leaf spring adjustable mounts. However, I can't pin point it to be sure. Mine gets so bad sometimes when I go over a speed bump it sounds like something is metal to metal. It's so loud that I would think it would be easy to locate, but it's driving me crazy. My car has about 75,000 miles on it. Any ideas or suggestions?
Old Jul 9, 2007 | 03:04 PM
Patches's Avatar
Patches
Check your sway bar bushings as well. If they're dried out, they make a heck of a noise similar to the one you described. I just had to grease mine as they were making some very loud clunking noises. Grease fixed it.
Old Jul 9, 2007 | 10:56 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I was just going to suggest the same thing. You are absolutely correct and they need to be replaced every couple of years too.
Old Jul 22, 2007 | 10:51 AM
wwnf's Avatar
wwnf
Default It's the shock or sway bar bushings
I believe it's the front shock mount bushings or the sway bar bushings. I'll change/lube them here soon to pin point it more, but I did tighten the front shock mount more and it seems to be less popping but I'm out of threads to tighten it anymore. I'm thinking of Koni FSDs anyway so I'll change the shock bushings then. I'll lube the sway bar bushings too and see if that helps. Since my 98 C5 only has 13K miles I believe the bushings are dried out and shrank some.
Joe
To Engine cradle noise???
