Is this a tuning problem
Old Jun 13, 2007 | 07:37 PM
bowtiebubba's Avatar
bowtiebubba
Default Is this a tuning problem
I had heads and cam installed a few months ago, they also tuned it. When im not running the AC and pull up to a stop, it idles down to 1000 rpms and after 30 seconds or so it will drop to 800 rpm. Which is fine. Now, when the AC is on and i pull up to stop it idles up to 2000 rpms and stays there for a couple of minutes before it drops to 1000 rpms. Can someone give me an idea as to whats going on. Thanks guys
Old Jun 13, 2007 | 07:49 PM
tiojames's Avatar
tiojames
Take it back to the tuner-it should not take 30 seconds to drop down to correct idle. Same with the A/C, the tuner can fix this, make sure they do the tune with the A/C on and off.
Old Jun 13, 2007 | 08:23 PM
bowtiebubba
I called them and told them the problem with the idle with the air on. He said he had never heard of that before but i could bring the car back and he would check it out. The problem is they are 5 hours away.I asked them when we were discussing them doing the work if the tune would be done right the first time because of the distance between us, said it wouldnt be a problem.
Old Jun 13, 2007 | 08:46 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
I can't help with what is wrong, but I would find out before the trip to have a good ideal what needs to be done. I could see you wasting a lot of time and not getting it fixed. I am sure someone here will be able to help. Good luck.
Old Jun 13, 2007 | 09:11 PM
bowtiebubba
Thanks,i hope someone has an idea of whats wrong.
Old Jun 13, 2007 | 09:28 PM
double-oh-coupe's Avatar
double-oh-coupe
Wow, I figured mine was the only one doing this. I'll idle at 1500 with the AC on, and it won't drop until I turn it (the AC) off. I'll be watching to see what your tuner says. (Just another example why this Forum is a great place!) Good luck!
Old Jun 13, 2007 | 11:45 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
it is a tuning problem, pm Englandgreen
he helped me out at CI8
Old Jun 14, 2007 | 01:46 PM
bowtiebubba
I dont know if this could be fixed by a mailorder tune. Missouri is a long way from Florida.
Old Jun 14, 2007 | 02:52 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
It is most definitely a tuning problem, there are 2 seperate tables for idle parameters 1 with the A/C on and 1 with the A/C off
Old Jun 14, 2007 | 05:40 PM
chaase's Avatar
chaase
St. Jude Donor '12
I had issues similar to that with my initial H/C tune where the idle wouldn't always drop right away. Go back and have them fix it.
I understand the distance is a pain, but they are going to fix it for you.
Old Jun 14, 2007 | 09:47 PM
99 vett babycar's Avatar
99 vett babycar
it's def a tuning problem. Either post in the tuning section or make a post on LS1tech.com(those guys REALLY know tuning)
Old Jun 15, 2007 | 07:49 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
My pleasure Ed
Old Jun 15, 2007 | 08:03 PM
edcmat-l1's Avatar
edcmat-l1
Theres more to it than that. Even if you have the idle set a XXX rpm, either with or without the ac on, if other things arent right, it wont idle right
Expected Idle airflow for one. Needs to match the actual, at least be close. Depending on the cam, sometimes you have to adjust the ETC scalar.
You also need to make sure that the commanded A/F ratio matches the actual. Theres a couple/few other things that need to be right/corrected/modified. but I dont have my software in front of me.
Its about 3 AM. I'M IN GERMANY!!!!
Old Jun 15, 2007 | 08:17 PM
vetpet's Avatar
vetpet
It's definitely in the tune. There are several tables that need to be adjusted to get it to idle properly as well as drop to idle speed right away when you come to a stop. I think you will have no choice but to take it back to the tuner. DO you know what tuning software he's using? If you can get a copy of your tune maybe someone with the same software can look at your tune and check the tables that need to be worked on before you drive 5 hours. I'm sure someone on the scan & tune forum here would then be able to help you. If not you can go to LS1 Tech forum for help or the software vendors site. You'll probably need to get a list with details on the mods you've done (cam specs, exhaust, intake, etc).
Old Jun 15, 2007 | 10:35 PM
bowtiebubba
The problem i have with taking back,beside the 10 hour drive is,will he get it right this time. Everyone here knows its a tuning problem,but i tell the guy that tuned it,and he says he has never heard of that happening before. Kind of makes me a little leary of his knowledge.
Seems like everyone you talk to has the best tuner in the world.
Old Jun 15, 2007 | 11:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hey, ED
Hows the car running?
BC
Old Jun 16, 2007 | 12:06 AM
Tech's Avatar
Tech
I'm in St. Louis and tune with HP Tuners but I don't have support for 02 Vette. I have a friend that does though. One of us can help you out. I'm not sure where Monroe, MO is though? KC side?
[Edit]I see you're up north near Hannibal. That's not too bad of a drive.[/edit]
Old Jun 16, 2007 | 02:44 AM
edcmat-l1's Avatar
edcmat-l1
He must not do many vettes. Anything with an ETC has these problems, and therefore needs the same tuning changes. Cable throttle bodies are a little different, and easier to tune.
Its these changes, that improve, or maintain the driveability quality after cam swaps, that make or break a tuner.
To Is this a tuning problem
