EVAP problem
Old Jun 14, 2007 | 12:32 PM
2002blackvette's Avatar
2002blackvette
3rd Gear
Default EVAP problem
Was getting codes 172 and 175 running rich, now I received a new code 442 DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected. My mechanic hears a hissing sound in the right rear, but does not have the equiptment to work any further and he recommends going to the dealer. Is there anything I should be aware of before I bring in to the dealer. It is a 2005 Auto.
Thanks for any response.
Old Jun 14, 2007 | 05:41 PM
AVB's Avatar
AVB
The EVAP leaking would be a vacuum leak and could be confirmed by spraying some carb cleaner around the area hissing I would think. Idle should change if the carb cleaner gets into the manifold via the vac leak.
The EVAP has quick disconnects everywhere.. I'd start spraying around those.
Arnel
