what wires are these
Old Jun 14, 2007 | 09:28 PM
Ackattack1's Avatar
Ackattack1
Default what wires are these
When I installed my clutch a few weeks ago I pinched some wires in between the bellhousing and torque tube. Now I'm having some issues. Anyone know what the wires that run across the bellhousing (perpendicular to the torque tube) are?
Old Jun 14, 2007 | 11:10 PM
blkvett01's Avatar
blkvett01
1) Reverse Inhibit Solenoid
(2) Skip Shift Solenoid
(3) Vehicle Speed Sensor (VSS)
and more the wires are for all the trans and wheel light many more.
Old Jun 15, 2007 | 01:02 AM
Ackattack1's Avatar
Ackattack1
forward of that.....where the clutch is
Old Jun 15, 2007 | 08:39 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default More info please
How about so more info about your problems?
The O2 sensor wires are close and maybe the starter wires, but if I remember everything else is in a harness.
Bob K.
Old Jun 15, 2007 | 04:40 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The transmission harness runs parallel to the torque tube but it comes down the bellhousing and runs back to the transmission, there is also another set of wires that come out and run to the left side of the bellhousing (still part of the trans harness) and these go to both front wheel speed sensors.
What problems are you having?
If the wires are damaged, the torque tube will probably need to come back out to repair or you could remove the harness by lowering the drivetrain and slipping the harness out (I've done this).
Old Jun 15, 2007 | 04:47 PM
Dope's Avatar
Dope
Resident moron
I did the same thing, luckily I realized my mistake before I damaged the harness.
Sorry, not very helpful, but it is easy to do
Dope
Old Jun 15, 2007 | 09:01 PM
blkvett01's Avatar
blkvett01
That is a picture of all the wires that run back through the harness. If you give me some codes i will look up witch one is giving you a problem. If no codes then it is a ground and you have to fix that too.
To what wires are these
