Hvac Question
Old Jun 15, 2007 | 01:05 PM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
Default Hvac Question
I have a '00 FRC and I've noticed that the A/C seem to stop cooling when car is under acceleration. Is this normal, or is something causing this to happen? I currently have a slow leak at the schrader valve on the low side hose where you add refrigerant. Is there anything else to fix this leak without changing out the hose. I do not want to add any type of stop leak. thanks.
