Had my diff fluid changed a couple of weeks ago. Just a maintenance change due to road racing....there were no issues or leaks.
Now I noticed a little leaking at the drainplug. And a little grinding on my first sharp turn in the morning when fluid is cold.
I watched the guy change the fluid and before I could stop him he placed the additive first, then the gear oil. GM fluids were used.
Is it possible that the additive is not completely mixed after several hundred miles....sitting in the bottom recesses of the diff. And that it is slowly seeping past the drain plug gasket.
Seems plausible in initial fill, not sure what the specific gravity of each is but once it heats up I would think it would mix. Also, when I re-install the drain I usually screw it part way in and then wipe under the seal so I don't tray any oil that could drip later. Not sure how much is coming out, but if it was just a drop or two that may be why as well.
can't wait to see the answer from someone who knows. I remember reading somewhere in here about doing a bunch of "figure-eights" to get it all mixed properly. I'm starting to hear some weird noises coming from ( I think) the rear on a slow sharp right turn...a groaning of some sort.
Howie!Howie! Your technician probably put the additive in first so he could just add gear oil to the full mark. Just easier than trying to leave room to add it after the gear oil. I think the additive is well mixed with the gear oil by now.
I know in the past one quart of oil was placed first then the additive and then the 2nd quart.......FRANK....the diff holds it all ..... no measurement !!!!!!
I don't hear anything after that first sharp, slow turn in the morning.
DH
Howie! I must say you do have good hearing in the morning also check out my post in the FI section.
Its gonna cost me $60+ in new fluids again and a washer but I'm gonna do it over. This time mixing the modifier into the gear oil before putting into the diff.
The differential is suppose to only hold 1.69 quarts of oil. Not 2 quarts. And 4 oz. of the additive. Some oils has the additive already mixed in with it.
Are you sure it's not overfilled?
You can could go and get 2 quarts of Amsoil or Royal purple for $20-$25 and do it yourself. Do the figure 8s, and if it doesn't chatter, then you won't need to add the additive. Amsoil and RP already as the additive in it. If it chatters, then you will need to add a little. Just don't put in too much additive.
Well its possible its overfilled.
But that seems unlikey. It was filled on a level surface. How can you overfill if the fill hole is on the side of the differential .... not on the top????
Well it WAS over filled......I let it drain till it stoped. And the whole underside was coated in oil....so it must have been WAY overfilled.
I will see if it stops leaking. I hope everything went out the overfill hole and that the side plate seals were not affected......I have already had that fixed twice.
I hope the little bit of groaning/grinding I am gettting on sharp turns is that I need to add a little more of the Additive as it was TOO diluted obviously......
Mine was blowing out the vent on top.Pulled fill plug and let it drain over night and next morning installed plug and washed.Not a drop and still clean after 2 years.Hope that fixes yours!
From a performance standpoint, the amount of additive is critical. Too little and it will chatter and too much and you will lose the limited slip ability. Sounds like a drain and do over to me to ensure the correct ratio.
Sounds like GOOD advise
Still had some drip marks after driving it even though I drained the overflll from the fill plug and cleaned up the oil drips/splatter.
I hope it is just some excess in nooks and crannies I could not reach or the drain washer.......otherwise my the top vent my be stuck
DH,
Leakage from the rear diff of C5s is very common and usually from these sources:
- Vent plug on top driver's side of diff. This vent is designed to vent overpressure. I've experienced some loss of fluid out this vent when the diff is very hot, such as on the track. I believe the failure of this part is rare.
- Leakage past fill plug. I can't seem to get my fill plug to seal. I fill to the fill plug, but believe the fluid expands somewhat when its hot causing the level to rise over the fill plug and then I get weepage. This is a minor inconvenience. I usually just remove the fill plug, let some drain out, then close it.
- The worst, and most common is a leaking axle seal - driver's side is by far the most common. As the vent is on the same side, it is easy to confuse the two. If you have a bunch of fluid on the driver's side and not the passenger side, I'd suspect driver's side axle seal leakage. There are many TSBs out on this.
DH,
Nice to hear from you. I had absolutely no leakage since my last driver plate seal job by GM a year ago. Then this mess started after me trying to do proper maintanence since I track it.
Do you think it being a little over filled ..... at most .3 qt since he managed to get most of the two 1 qt bottles could blow the seals ????????? Or cuase the vent to stick open?????
