Update on Comp Cams 918 Springs
Just thought I'd let people know that I talked to Comp Cams about their 918 springs, and they verified that they did have a bad batch. They said that the batch was about a year and a half ago, and they tried to recall them, but some vendors disreguarded the warning and sold the springs anyway.
They said that the problem was immediatelly fixed and there is currently no problem with their 918 springs, and there hasn't been for a long time. They did recommend buying the springs directly from Comp Cams to make sure that you got a good spring, as there's no way to tell who might be selling some old springs that should have been sent back or thrown away.
Just thought I'd give you all a heads up.
Dope
Here is a comparison photo of the original 918 (dark w/ blue stripe) and the revised 918 (shot peened silver). The new design is a little shorter, has a higher spring rate, and is good for .625" lift (up from the original .600" lift). I am glad that I held off my installation for these new springs.
