Re: Getting dynoed again today.......TPIS headers installed (leanhtuan)
OK, here is the graph. I gained almost 7 RWHP and 13 TQ. It's about what I expected. The graphs shows my old run (330.1 RWHP) and my new run (336.6 RWHP) superimposed.
Those of you thinking that these headers will give you 15-20 HP are mistaken unfortunately.......
Re: Getting dynoed again today.......TPIS headers installed (Bluewasp)
How does the extra power feel?? Are you happy with the mod?
Yes, very happy with the mod. It sounds better too.
I can't tell a SOTP difference, however, it did lower my average ET by .1 and increased my mph by 1.5
Re: Getting dynoed again today.......TPIS headers installed (2thDr)
[Modified by 2thDr, 9:24 PM 10/26/2001]
I'll take a cam shaft over long tube headers anyday...much more efficient use of mod dollars. Of course, LTs on top of a cam shaft will rock! 2th, I see a cam shaft in your near future... :D :smash:
Re: Getting dynoed again today.......TPIS headers installed (Viprklr)
After you spent all that money, you might want to spend a little more and get a MAFT. If you are running too rich or Too lean (which is common with these types of mods) you will get addl HP and TQ if you tune using a MAFT. Prelim number on my MAFT gave me 18 addl LB's of TQ (based on EASE scan). I'm doing a DYNO on 12/1 to get the actual results
Do you monitor your air/fuel ratio? You may be losing a lot of HP and torque by running too rich, or too lean. Just curious. :chevy
Me? I've autotapped the car and it runs fines on the A/F mixture. I picked up an honest 25-30 horsepower. I need to have my cats removed to see what a wide band O2 would read exactly, but the autotap says I'm running good.
2thDr: Very nice gain, especially TQ, through out the RPM range. :D Who cares about peak gains!!! Can't wait until I get my dynoed tomorrow.:smash: Didn't dmc1007 gain 16RWHP with the TPIS LT on his car?
DMC1007: Do you happen to have the dyno graph, before and after the TPIS install?
Finally I got my car dynoed with the TPIS on. I will post the graph as soon as I get it scanned into the computer.
2thDr is right on the money regarding to PEEK RWHP/TQ gains. :smash: :smash: :smash:
I only gained 6RWHP & 11.5TQ @ peak. But I picked up a solid 18-20RWHP/TQ increase across from 4100RPM to 5500RPM range.
:cheers:
Even with the stock plugs replaced (with NGK TR55), the engine pinged again right at 5600RPM. Jayson @ MTI said he has seen it on quite a few non-heads&cam LS1's and it's pretty normal. I will get it checked out with AutoTap soon and report back.
