How often do Blackwings need to be cleaned?
Old Oct 26, 2001 | 12:42 PM
Tek's Avatar
Tek
Default How often do Blackwings need to be cleaned?
I have been pondering getting a Blackwing. I know it comes with a kit to clean the filter when needed. I want to ask those who have one, how often do you have to clean your filter? How long does it take?
Tek
Old Oct 26, 2001 | 12:50 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Default Re: How often do Blackwings need to be cleaned? (Tek)
Tek,
The cleaning kit is optional... not included.
The filter has in indicator on it that is activated by a vacuum within the filter. If the filter is clogged, the vacuum increases and pops the indicator in.
Cleaning involves spraying the cleaner on, rinsing with a hose, drying time, and re-oiling the element. Probably best to allow it to dry overnight, but not totally necessary.
How often? Depends on your environment, but I think 25k - 50k miles under "normal" conditions.
Good luck,
Old Oct 26, 2001 | 03:19 PM
KJT's Avatar
KJT
Default Re: How often do Blackwings need to be cleaned? (SDVette)
Good luck,
25k - 50k miles? That is a lot more than I had thought. I would have thought that you would need to clean your Blackwing every 10k-12k miles like a regular filter. Of course, I live in NM which is a giant dust-bowl at times..... I was planning on cleaning my Blackwing at around 15k due to all of the dust here.
-Ken
Old Oct 26, 2001 | 03:44 PM
SDVette's Avatar
SDVette
Default Re: How often do Blackwings need to be cleaned? (KJT)
From the Donaldson brochure:
"Cleaning your Blackwing high performance air filters is recommended between 50,000 and 100,000 miles on typical driving applications."
Old Oct 26, 2001 | 05:00 PM
bdavies's Avatar
bdavies
Not real familiar with the Blackwing, but I pulled my K&N out after 24k miles and it was so filthy I couldn't believe it. The ridges were filled with dirt and the whole thing was covered in grime. It took me 20 minutes with a soft-bristled brush, the K&N cleaning solution and a hose to get it all off (at first the water flowing through it came out black). I re-oiled, let it dry in the sun for a couple hours and re-installed. I actually noticed a significant increase in throttle response and high-end pull. I don't think I will ever let it go past 10,000 miles without a cleaning any more.
To How often do Blackwings need to be cleaned?
