new clutch slipping?
Old Jun 15, 2007 | 06:59 PM
nvygw171's Avatar
nvygw171
Default new clutch slipping?
i had a 425 whp horsepower motor put in a month ago, and decided it would be a good idea to replace the clutch / pressure plate, resurface the flywheel, and replace the slave cylinder. i went with a spec clutch as good for 430 whp, imediatly noticed that it was shaking the drivetrain when i would start off in to first, checked the forum and it said it would wear off in 500 or so miles.... ok no big deal. i had only put roughly 400 freeway miles on the new motor and clutch, with about 3 or 4 punchs from a roll never did it slip, then one morning i start it up, get on the freeway and it starts slipping at 3/4 throttle.
took it back to the clutch installer thinking maybe a leaky rear main but the clutch was clean. does this seem normal for a clutch/pp to go over night when it was driving fine the last time i pulled into the drive way?
Old Jun 15, 2007 | 07:04 PM
BrianG01's Avatar
BrianG01
400 freeway miles wouldnt break in a clutch as well as 50 city miles, it needs a lot of stop and go. Not sure whats making it slip though...
did the shop offer any suggestions?
Old Jun 15, 2007 | 07:23 PM
nvygw171's Avatar
nvygw171
no but they are bleeding the clutch fluid to see if that's it
could it be do to the fact that my butt is leaking red stuff?
the vettes butt that is
To new clutch slipping?
