Professional Tire plug kit, makes plugging tires a snap.
Old Oct 26, 2001 | 06:45 PM
jetskifast's Avatar
jetskifast
Default Professional Tire plug kit, makes plugging tires a snap.
Some low life inserted drill screws into each of my rear tires, on my 01 Jeep Grand Cherokee :mad
Gave me a chance to test out my Corvette plug kit http://www.safetyseal.com 800-888-9021
Took less than 5 mins to repair each tire. Tools included in kit worked out great. Kit also includes extra parts if you should break an insertion needle.
According to Safety Seal, plug is permanent and will out last tire.
Just picked up a nice low profile 250 PSI air pump at Costco, cost $19.99.
[Modified by jetskifast, 4:59 PM 10/26/2001]
Old Oct 26, 2001 | 06:52 PM
Z06inator's Avatar
Z06inator
Default Re: Professional Tire plug kit, makes plugging tires a snap. (jetskifast)
Looks like a nice kit..
I have always preferred plugs over patches. Patches do not protect the plies of the tire from moisture (and rust!). That is especially important in freezing conditions where freeze/thaw cycles can really impact the tire.
A newer development is the 'plug-patch'. This is just what it sounds like - a combined plug and patch. It must be applied from inside the tire. It is supposed to be the best of both a patch and a plug.
Old Oct 26, 2001 | 06:57 PM
jetskifast's Avatar
jetskifast
Default Re: Professional Tire plug kit, makes plugging tires a snap. (BrianK)
Safety seal plug comprises 21 plies of high grade synthetic yarn completely embedded in a super sealing vulcanizeable rubber composition.
Old Oct 26, 2001 | 07:01 PM
MelloYellow's Avatar
MelloYellow
Looks nice.
What didja use to cut off the top of the plug?
Old Oct 26, 2001 | 07:43 PM
jetskifast's Avatar
jetskifast
Default Re: Professional Tire plug kit, makes plugging tires a snap. (MelloYellow)
Mellow
Kit comes with razor blades :)
Old Oct 26, 2001 | 11:33 PM
vk's Avatar
vk
What is the price for that kit?
Old Oct 27, 2001 | 02:48 AM
6SPEEDY's Avatar
6SPEEDY
Default Re: Professional Tire plug kit, makes plugging tires a snap. (vk)
Do you think that would work with run-craps?
Dave
Old Oct 27, 2001 | 03:11 AM
4DCYKEY's Avatar
4DCYKEY
Jetskifast,
I just noticed a nail in my rear tire yesterday as I was cleaning the car. I will be taking it to Jim, the tire tech that mounted my rims and tires for me after Big O chickened out. Maybe I'll pick up the kit too...
Herb
Old Oct 27, 2001 | 04:26 AM
Brazen C5's Avatar
Brazen C5
Jetskifast- Did you plug the tires on the spot with the tires on the SUV?
Old Oct 27, 2001 | 06:01 AM
jetskifast's Avatar
jetskifast
Default Re: Professional Tire plug kit, makes plugging tires a snap. (6SPEEDY)
6Speedy
should work fine on run flats:)
VK
Purchased kit for $65. Ordered from buddy how owns auto repair shop. Have seen the cheaper kits at Pep boys and so on. Kit tools are first class, not small plastic handle tools, all metal.
Herb
Repair plugs look to be high tech.Synthetic yarn embedded in supper sealing vulcanizeable rubber composition.Plugs seem to melt into place. Tires have had no air loss after plugging so far:)
Brazen C5
Plugged tires right in place. Did not remove wheels:)
[Modified by jetskifast, 4:05 AM 10/27/2001]
Old Oct 27, 2001 | 09:05 AM
Tom/99's Avatar
Tom/99
Sounds like a good kit to have. Thanks. :chevy
Old Oct 27, 2001 | 12:13 PM
Austrian Vette's Avatar
Austrian Vette
Good idea to have such a set!!!
Michael
Old Oct 27, 2001 | 01:06 PM
vk's Avatar
vk
Considering it costs $50 to plug a tire each time I'd say that is a super deal
Old Oct 31, 2001 | 04:09 PM
Skeeter1's Avatar
Skeeter1
it was probobly some trailer trash :seeya
[Modified by Skeeter1, 3:11 PM 10/31/2001]
Old Oct 31, 2001 | 04:51 PM
SeaFive's Avatar
SeaFive
Very nice set up.
Is the air pump powered via 12 volt? Or house current? Thanks
Old Oct 31, 2001 | 09:22 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Jet, sorry to hear about the Tire Fiasco! :( Glad your new Kit works well! :) I have had a plug set like this one for a long time and use it often on the Job. :yesnod: IMO, it is the best one on the Market.
vetterdstr :flag
Old Oct 31, 2001 | 10:55 PM
Urcvb2's Avatar
Urcvb2
Default Re: Professional Tire plug kit, makes plugging tires a snap. (vetterdstr)
Hey, how did know I just put 4 non run-flat B.F. Goodrich G-Force KDW's on my 98 C5 ? Great info, think I'll run out tomorrow and buy the same set-up.
:cheers:
Thanks, Rudy
To Professional Tire plug kit, makes plugging tires a snap.
Old Nov 2, 2001 | 04:50 AM
jetskifast's Avatar
jetskifast
SeaFive
Air compressor runs on 12 Volts. Costco sells them cheap.
vetterdstr
Kit worked out great :) Wish I knew about this kit years ago.
Old Nov 2, 2001 | 10:37 AM
Tracy's Avatar
Tracy
jet-
Thanks for this good info. That is a nice looking plug kit. I have some cheapo crappy $4.95 kit that I carry in the car, and a small, foot powered pump which actually works good. I have yet to use the plug kit, but I'm sure that when I do, I'll be cussing :cuss and muttering about what a no-sealing piece-of-junk kit I have. Maybe I'll upgrade to this "Cadillac" of plug kits.
Regarding that 12V pump....I have YET to have one or use someone else's that doesn't blow the damn lighter fuse in short order, which is why I have this foot pump. If you do use a 12V pump, make SURE you use the lighter socket and NOT the cell phone charger socket in the console. That fuse has no "umph" at all.
Old Nov 2, 2001 | 01:52 PM
hmert's Avatar
hmert
I picked up a nail in my Goodyear runflats a few months ago, and was told (by Goodyear) that those tires could not be plugged, that the tire had to be taken off the rim and patched from the inside at a cost of $40. The Chevrolet dealer said the same thing (but for $20). I think it may have had something to do with the speed rating on the tires.
