Key fob memory problem?
Old Jun 18, 2007 | 03:50 PM
ITLBTU's Avatar
ITLBTU
Navigator
Default Key fob memory problem?
Has anyone else had a problem with the #1 key fob activating the # 2 driver, and the #2 activating the #1 driver? Is this something that needs to be re-programmed? I just bought my '02 Z a few weeks ago and it was like that when I got it.
Old Jun 18, 2007 | 08:16 PM
65GGvert's Avatar
65GGvert
Probably memorized in reverse order when programming through the DIC. You can always reprogram. Just for grins, try holding down the lock and unlock buttons until the horn chirps and see if the syncronization got confused. Do both fobs. If not, then go into the DIC and program #1 first then #2. You could also just reprogram the memories with the buttons on the door and switch the settings to the number button you want.
Old Jun 19, 2007 | 12:58 PM
ITLBTU's Avatar
ITLBTU
Navigator
Thanks. I'll try that. My last Vette was a C4, and it didn't have all the bells and whistles that this one has.
To Key fob memory problem?
