Differential break in procedure
Old Jun 18, 2007 | 06:28 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Default Differential break in procedure
Whats the correct break in procedure for a new differential?
Thanks,
jeff
Old Jun 18, 2007 | 08:37 PM
vettenuts's Avatar
vettenuts
I'm not sure which you have but on the DTE no RPM's over 3,000, no lugging and no high power acceleration for 350 miles. And most of all, no dyno's!!!!
I basically did most of my driving on back roads so I was using the motor to pull the car and then hold it back as well so the gears would be loaded on both sides. I would think DTE's requirements would fit pretty much any differential.
Old Jun 18, 2007 | 10:09 PM
JeffC5's Avatar
JeffC5
Thats pretty much what I'm doing, but I think I'll try to do it for 500 miles. Thanks for the info.
jeff
Old Jun 18, 2007 | 11:29 PM
rws.1's Avatar
rws.1
When GM replaced the differential in my SRX, they dorve it for 50 miles at 50 mph or under and then let it cool over night,
I was then restricted to 50 mph or under and no full throttle for the next 500 miles.
To Differential break in procedure
