hp gain
Old Jun 19, 2007 | 10:35 PM
brad6285's Avatar
brad6285
Default hp gain
i have a 2003 ae vert with a bpp vortech cai and a set of lg street series headers on it. ecs installed the headers anddid a street tune and dyno tune resulting in 340 rwhp and 350rwt. my question is a member is selling a set of z06 heads (sodium filled) if i put these on my car with a zo6 cam what kind of hp gains could i expect? thanx brad
Old Jun 19, 2007 | 11:32 PM
spiral04's Avatar
spiral04
What's up Brad. Haven't see ya post in awhile. I'm no expert, but my guess would be about 35-40rwhp. Someone will chime in who knows more than me. I'm presently saving for some AFR's or Trickflows and custom cam set up. Everything depends on what your final goals are. For me, I'm trying to get as close to 500 rwhp naturally aspirated. Hope everythings been well for ya!
Jason
Old Jun 20, 2007 | 01:42 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I put a set of LS6 (Z06) stock heads on my 98 A4--gained only about 12 rwhp--with a .221 .221 cam w/.567 lift @ 114 --I gained another 32 RWHP so HDS & cam was 44 RWHP---With a stock Z06 cam I don't think you'd gain much HP --- with the LS6 heads and the Z06 cam i would guess only around 25-30 RWHP---I would go with a different cam-- I chose the .221 to pass Calif Emmissions
Old Jun 20, 2007 | 05:11 AM
SLO C5's Avatar
SLO C5
From: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
When doing a heads and cam swap, the labor and tune(most places charge $1500 labor, $500 tune) ends up costing nearly as much as the parts. If you are going to do it, go with something bigger/better than a stock LS6 setup. You can get around 430rwhp with a good set of AFRs or TFs, and a CA smoggable 224ish cam.
Get it done the way you want the first time.
To hp gain
