Help
. i tried sea foam in intake manifold twice, colder plugs gap at .50, new msd wires, next is knock sensors, and air temp sensor, but what i want to know is if the knock sensors are covered under warranty, and how will i know if they are bad. aslo want to know were the air temps senor is at and if there are any more. any advice would help and thanks again.
DTC P1518
Throttle Actuator Control (TAC) Module Serial Data Circuit
DTC B2262-B2265
Mirror Position Sensor Signal Circuit
DTC B2282-B2285
Battery 1 or Battery 2 Voltage Out of Range
U1040 - Loss of Class 2 Communications with ABS
U1016 - Loss of Class 2 Communication with VCM
U1016 - Loss of Communications with PCM
U1064 - Loss of Communications with DIM
U1088 - Loss of Communications with SDM
U1160 - Loss of Communications with DDM
U1176 - Loss Of RFA Communications
If you are getting a low reading, try charging the battery. If it still doesn't improve (you have to wait a while after taking charger off to measure voltage), take it to a auto store for a load check. A load check is the preferred method of checking a battery.
DTC P1518
DTC B2262-B2265
DTC B2282-B2285
The air temp sensor is inside the MAF It is on the inside close to the out side edge of the opening. Have you ever cleaned the MAF with a spray cleaner?
Bill C
BC
BC
