MSD coils - any reviews?
Jun 20, 2007 | 03:11 PM
Do these offer any advantage over stock?
Jun 20, 2007 | 03:13 PM
Do a search, this horse has been beaten. I believe the answer was NO. If it's like the MSD coil(s) I tried on my 69' (About 4 blasters and finally an HVC), I would never buy another MSD coil!
Jun 20, 2007 | 03:18 PM
Cruise-In VII Veteran
I have never used them, I have used the stock coils past 700HP, other than the red color, I don't see any reason
Jun 20, 2007 | 03:22 PM
I hear they'e extremely effective at wallet lightening.
Jun 20, 2007 | 03:42 PM
I have read the GM truck coil are better and much cheaper.
Jun 21, 2007 | 06:49 PM
Quote:
Originally Posted by
vettenuts
Well, Ihink I get it...do you think the wife will notice if I swap herSuburban coils in?
Thanks, all - great info.
Jun 21, 2007 | 07:15 PM
Moval49er
Only if you don't replace them
Jun 21, 2007 | 11:25 PM
vettenuts
Basically the same as the Ls2/Ls7s, smaller and deliver same spark with less power input. I plan to use them when I go to exposed valve covers.
Jun 22, 2007 | 12:01 AM
St. Jude Donor '08
MSD High voltage coils are only nessicary in SOME FI/nitrous applications.
I used the 6AL ignition control computer on my truck with much better results, but my 97 silve doesn't have individual ignition coils.
Oct 6, 2007 | 12:52 AM
TheRadioFlyer
Why would it only be SOME FI/No2? What are the benefits?
Oct 9, 2007 | 11:28 PM
Oct 10, 2007 | 12:36 AM
It has to do with the much higher cylinder pressures involved w/FI and nitrous engines.
More complete combustion- via a multiple spark with it's longer duration - combined with the correct choice of plug (heat range/gap. etc)
Cylinder pressures that get high enough need more attention to the ignition of the air/fuel mix.
HTH
