Big differnce between nology and msd wires.
Old Jun 21, 2007 | 03:28 AM
c4vetteontop's Avatar
c4vetteontop
Default Big differnce between nology and msd wires.
One of my nology wires got burned and spliced in half.( Car was running like ****...bogging out..backfiring..etc) So instead buying a set of 8 nology wires i just bought a set of 8 msds and replaced the one wrecked nology with a msd. Will it make a differnce in my spark or should i just replace all 8 with the msd wires. What will give me the best performance. I seem to feel like my car backfires alot more when befor. (Ive got no cats with headers and borla)...could just be me.
Old Feb 3, 2008 | 07:46 PM
miami08VETTE's Avatar
miami08VETTE
Wires are sold in sets for a reason. Change to all MSD and keep them electrically equal.
Old Feb 3, 2008 | 10:06 PM
ruffian's Avatar
ruffian
You have seperate coils for each plug... I'd say you'd never know you had a mix and match set. For that matter I think it's a safe bet there's no diff between a full set of nology's or msd's... kind of like oil threads imho.
bob
Old Feb 4, 2008 | 05:03 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Save your money, Delco wire are just as good as the rest. The wires are so short, resistance is not an issue if that is why you changed.
Old Feb 4, 2008 | 06:03 PM
lar66BB's Avatar
lar66BB
Yep, what he said, save your money.
Old Feb 4, 2008 | 06:11 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I disagree on the wires being the same. Take your volt/ohm meter and read the resistance of the stock wires and see what that is per wire. Then use the same meter and check the resistance of the MSD or Nology wire and see what the reading is. IIRC, the stockers are about 350+ ohms. The MSD's are about 35 ohms or so. Less resistance = more amperage = hotter spark.
Old Feb 4, 2008 | 07:43 PM
screw991le's Avatar
screw991le
Which on a stock system makes no difference.
To Big differnce between nology and msd wires.
