Ok, Installed 3.90, my speedometer has not changed???
Old Jun 24, 2007 | 07:25 PM
Blown-Interceptor's Avatar
Blown-Interceptor
Default Ok, Installed 3.90, my speedometer has not changed???
My speedometer is excatly the same as when I had 3.42, no change. I know I need to change the gear ratio with tuners, but my speedo should be off a little, right?
Also, I have not really laid into the pedal, I am breaking the gears in, but it does not seem like I have 3.90, still feels like I have 3.42???
Old Jun 24, 2007 | 08:03 PM
vettenuts's Avatar
vettenuts
Is this a 6 speed?
Old Jun 24, 2007 | 08:06 PM
RobWilson's Avatar
RobWilson
No corrections needed on 6 speed cars.
If you can't tell a difference between 3.42s and 3.90s, something is up. Wait until you are finished with the break-in before passing judgement. You will notice.
Old Jun 24, 2007 | 08:08 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Since the reading is taken from a wheel speed sensor, the only thing that will affect the speedometer reading is tire size. A gear change won't do it.
No tuning is required for a gear change on M6 cars.
A4 cars need it to adjust shift points and prevent from over-revving, that's it, nothing to do with the speedometer.
Old Jun 24, 2007 | 08:19 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Blown-Interceptor
Originally Posted by vettenuts
Is this a 6 speed?
Yeah, 6 speed.
Old Jun 24, 2007 | 08:20 PM
Blown-Interceptor
Man, I sure hope so.
Old Jun 24, 2007 | 08:27 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
Old Jun 24, 2007 | 09:41 PM
Mike Mercury's Avatar
Mike Mercury
No (speedo) corrections needed on 6 speed cars.
no corrections for any C5 (6 speed or A4).
(looks like johnnyvettes beat me to it !!!)
you made a 14% ratio change. It won't be a day/night difference... but it will be noticeable. Let the gears break in first... then do a couple 1/4 mile runs.
Old Jun 24, 2007 | 09:46 PM
Nyvetteguy007's Avatar
Nyvetteguy007
I went with 4.10's and I notice a big difference...
Hows 6th gear for you?.....same as it was or some more ooomph to it?
with my 4.10's 6th gear is now usable and acceleration off of the line is noticably better...LOVE them....had them put in by Chuck at Corvettes of Westchester.....
Old Jun 24, 2007 | 10:00 PM
Blown-Interceptor
I just read about no need for a speedo change on your website. Last time I did gears on a car was on my 2000 Camaro. So I was pretty shocked when the speedo was the same.
That being said, I hope once the gears are broken in, I will notice a big difference. That is a pretty big jump...3.42 to 3.90, I would assume.
Old Jun 24, 2007 | 10:45 PM
evo2ls1's Avatar
evo2ls1
Default i love em
i have bolt ons on my 99 frc i did 3.90's and i love em every gear is where it should have been from the factory. wait till the break in point is over then row through 1-3 you will notice
Old Jun 24, 2007 | 11:43 PM
Blown-Interceptor
I bought the car used, I just hope I did not have 3.90's in there already.
Old Jun 25, 2007 | 05:45 AM
vettenuts's Avatar
vettenuts
The reason I asked if it was a six speed is you can go to the DTE web site and look at the approximate RPM in each gear. From that you should be able to tell your gear ratio. Also, when I broke mine in I had a hard time too distinguishing the new gears but when driving in 4th I did notice more exhaust noise because the motor was turning faster. Once broken in and you can get on it a bit more, the gear are now much more noticable
Old Jun 25, 2007 | 07:56 AM
Nyvetteguy007
Yikes....who installed them? You or a shop? Was the original ratio tag on yours?
The one that Chuck at CoW installed in my car has a BIG 4.10 on the diff cover so there is no question later on down the line...
Old Jun 25, 2007 | 10:24 AM
Blown-Interceptor
A couple of forum member's helped me out, they did a great job!
http://forums.corvetteforum.com/show....php?t=1740077
Old Jun 25, 2007 | 11:43 AM
Nyvetteguy007
Cool... doyou have the old gears..theres gotta be a way to ck the ratio on them...
To Ok, Installed 3.90, my speedometer has not changed???
Old Jun 25, 2007 | 11:48 AM
Blown-Interceptor
I just looked on the back of my old diff...it says 3.42.
Old Jun 25, 2007 | 11:50 AM
Nyvetteguy007
whew.........
Old Jun 25, 2007 | 12:24 PM
Darkhalf's Avatar
Darkhalf
Fbody's do require a tune for gear changes, Ybody's do not obviously.
Enjoy those 3.90's!
