Do you have to remove the steering wheel to replace the plastic shroud that sits behind the steering wheel? I know it comes in 2 pieces and there is a torx screw on the bottom. Are there any short cuts, tips, ...?
Are you putting your's back on? Mine is loose and I need to replace. Someone said you have remove the steering wheel?
Regards-
John
You do not need to remove steering wheel.
There a two torq screws underneath the bottom case and one screw on the top case that is only accessible aftre you remove the bottom case.
The top screw is on the right side just in front of the turn signal lever. It has a different kind of socket (torq like) except it's on the outer edges, )(not sure of the correct name).
Don't think you need a new case, just re-tighten the upper screw.
