FAST intake 78 or 90 mm.?
Thanks for any feedback.
The best head for your combination would be AFR's milled to 59cc's, but if you are on a budget go with TSP or PRC stage 1.5 or 2 LS6 heads, or do the Livernois Stage II exchange and be sure to have your stock heads milled down to 62cc or 59cc to bump your compression. Give LGMotorsports a call they will point you in the right direction since it is their cam.
To answer your original question, YES the FAST 90mm intake is worth the money especially on a heads/cam car, you will see 20+rwhp over your stock LS6 intake with the G5X3 and heads with no loss of power down low. Also I would suggest a LS2 throttle body to use with the FAST and just purchase the plug 'n play LS1 to LS2 TB adapter harness.
I am not a nitrous expert but I would presume the best place to place your nozzle would be either in the air bridge or in a TB spray ring. I don't think the spray would be optimized in the intake.
I don't know anything about Nitrous but I believe the FAST has ports that can be punched out near each injector for the nozzles. There is also a burst disc that can be added underneath for nitrous use. Best bet is to contact Tony Mamo and get it ported for future expansion to aftermarket heads. He has a lot of experience with this intake
