best full face clutch?
The clutch feel is very close to stock with a little firmer feel at the pedal and smooth engagement on every shift.
If you’re interested shoot me a pm.
Julian
(908) 317-4496
The only clutches that are going to have truly stock drivability (pedal pressure, chatter resistance, quiet, etc) are going to be...stock-style clutches. LS6/LS7/Luk gold (I think that's what it's called). But none of them are going to be "brickhouse tuff". If you just like to cruise around and you don't run your car too hard (or race it), a stock style clutch will probably hold up just fine.
Any of the heavy duty aftermarket clutches WILL NOT drive exactly like stock. I've driven a bunch and they all have their issues. The high-end ones like Exedy, Textralia, Cartek, etc will hold a ton of power and CAN be driven smoothly enough. They will definitely not drive like stock, however. There is always some level of increased pedal effort, shortened engagement period, potential for chatter, most are noisy when cold, etc etc etc.. For example, I can launch smoothly in daily driving 8/10 times with my Exedy but if I let the revs drop a little too much, or go a little too high, it can rattle the crap out of the car.
My advice, if you're making pretty decent power (judging from your sig probably at least 425rwhp on a dynojet), then spend the money and get a high-end clutch. They are plenty bearable in daily driving and will hold the power without breaking a sweat. I've been driving my Exedy for about 3 years as my daily car with zero issues - I'm sure similar high-end clutches will perform the same. It's kind of a bear in stop-n-go traffic but I put up with it
Dope
Very true, research is very important, for example some places can only produce high priced hand grenades that they call engines. You wouldn't want to buy anything from them.
