Intermittent Headlight Issue
Old Jun 26, 2007 | 01:25 PM
tac4005's Avatar
tac4005
Default Intermittent Headlight Issue
On occasion, for the last few weeks, the passenger side headlight doesn't pop up. After a couple of re-starts, it pops up and works for days (and nights). What should I do cause I'm not interested in getting pulled over at night with only one eye open!
Old Jun 26, 2007 | 01:54 PM
JJ 86's Avatar
JJ 86
I have the same problem but on mine the driver side doesn't pop up on from time to time. I'm curious as well as to what the solution may be.
Old Jun 26, 2007 | 02:35 PM
flir_man's Avatar
flir_man
The motor has a plastic gear inside it that strips out over time. There are kits available that have bronze gears. Part of the R&R of the motor requires you to remove the lid that covers the head light assembly. When you reinstall the lid make sure that it does not rub on the hood, I seen that before.
Thanks,
flir_man
Old Jun 26, 2007 | 04:40 PM
DeeGee's Avatar
DeeGee
If its a stripped gear you'll get a grinding noise when the motor operates
Any noise?
Old Jun 26, 2007 | 05:20 PM
tac4005's Avatar
tac4005
Default no noise
Any noise?
Nope, no noise. Just doesn't pop up...
Old Mar 22, 2018 | 10:28 AM
ralee0047's Avatar
ralee0047
Cruising
Have the same problem. Passenger pop-up but driver side intermittent
Old Mar 22, 2018 | 01:22 PM
helga203's Avatar
helga203
Default Pop up
I had the same problem for years in till a member told me I had to have higher then 13v which only happens at start up. So if I get caught in the rain while the cars been running awhile I only get one light to pop up. So I have to pull over turn the **** on the back of the light .You do this with the head light off. Turn it a couple of turn which ever way is the easiest to turn them turn it back. Then your light will work. I do this every time I get caught in the rain or night.i tried everything to fix this with no luck.
Old Mar 23, 2018 | 12:45 AM
My Vette Life's Avatar
My Vette Life
disconnect the motor and spray contact cleaner on both ends of the cable. If it dont work, then pull off that rubber boot from the dial and turn the **** a bit then power it on again.
Old Mar 23, 2018 | 11:21 AM
GCG's Avatar
GCG
Originally Posted by helga203
I had the same problem for years... ...turn the **** on the back of the light... ...Then your light will work. I do this every time I get caught in the rain or night.i tried everything to fix this with no luck.
You might have damaged or missing bump stops. The way the headlights work is not based on predetermined positions. When the headlight doors open or close and they reach the end of their travel, they press against the corresponding pair of rubber bump stops. As a result the current through the headlight motors increases and that is sensed by the Headlight Door Control Module, which in turns cuts power to the motors.
If there are missing or damaged bump stops, the motor might keep working longer than really needed, which could result in over torque. If that happens, the next time the motor is operated it would require more torque to perform the action. That would mean more current than normal and the possible intervention of the Headlight Control Module, shutting again the motor before the door actually moves.
Having to manually relief the pressure in order for it to work is consistent with this.
I would check all rubber bump stops (4 per side) and if you need replacements you can order them from here.
Also, there is a TSB regarding them, that calls for shimming the driver's side motor.
Check the following pictures to see where they are located.
To Intermittent Headlight Issue
