HELP with CODES???
Old Jun 27, 2007 | 09:44 PM
-Blue Vette-'s Avatar
-Blue Vette-
Default HELP with CODES???
I'm trying to figure out why my windshield wipers will not return to home position/dock. They're stuck in the middled of my windshield and will not go down. After doing a few searches I determined that it might be my wiper motor.
I checked my codes and I've listed all of them below. Can anyone help me out with these codes?
AO-LDCM
B2282H
B2284H
B2262H
B2264H
UI255H
U1016H
U1064H
U1096H
A1-RDCM
B2283H
B2285H
U1255H
U1064H
U1016H
U1096H
BO-RFA
C2100H
C2105H
C2115H
U1000H
U1016H
U1255H
U1064H
Old Jun 28, 2007 | 09:51 AM
Mac11's Avatar
Mac11
Mine did some of those when the battery went south. Have you changed it yet ?
Go here for Code breakdown : http://www.southerncarparts.com/info...hp?pages_id=12
Old Jun 28, 2007 | 10:42 AM
sgreen4067's Avatar
sgreen4067
open your hood and check the 2 bolts that sit on top "in the corner by the driver side firewall, mine did the same thing and the 2 bolts were loose, once i tighten the 2 nuts, wipers worked fine again.
Old Jun 28, 2007 | 01:28 PM
-Blue Vette-
That's the link I needed. I took my battery out to have it load tested last night. It checked out fine. The codes where generated when I removed the battery.
Originally Posted by sgreen4067
Open your hood and check the 2 bolts that sit on top "in the corner by the driver side firewall, mine did the same thing and the 2 bolts were loose, once i tighten the 2 nuts, wipers worked fine again.
Are these ground bolts for the wipers? I'll check it out when I get home.
It rained hard here the day the wipers started freakin out. Actually it's been raining hard here almost everyday for a month. I checked the drains/utters and they where clogged with leaves and junk. This a typical problem other forum members had experienced when the utters where clogged. The water can't drain fast enough through the utters so it rises up and eventually gets on the motor. I guess it shorts the motor out. The wipers still work, but they won't go back to home position when turned off.
To HELP with CODES???
