Bad track times!!
Old Jun 23, 2007 | 09:58 PM
JuicedVette036's Avatar
JuicedVette036
Default Bad track times!!
I finally made it to the track last week with my 99 6 spd, stock. I had been reading about expected times for a stock vette and I saw low mid 12's to low 13's. My times were 14.0, 14.2, 14.4. I have to admit I did spin a lot at the light due to my street tires, but I didn't think it was enough for those times. There were evo's and srt's running low 13's.
Will drag radials improve my launching?
Old Jun 24, 2007 | 12:05 AM
McLude's Avatar
McLude
Man that's what I'm afraid of. I think I want to hit the dyno for a baseline before I go to the track to make sure it's my technique and not my car that is to blame. I'm new in Miami right now too, where did you go to run the car and where would be a good place to dyno before I hit the track here in town? Oh yeah and remember, they may be running low 13's but they are all probably at like 20 psi and you're at 0 psi
Old Jun 24, 2007 | 06:51 AM
NITRO UK's Avatar
NITRO UK
Originally Posted by 97vetteman
This makes my Vette's first trip to the track look good I ran 13.96, 13.70, 13.67 & 13.96 I know I'm A4 and your M6 but I was taking it easy no burnout and not even loading the converter.
Spinning a lot off the line is gonna hurt your times!
What was your 60ft time?
What was you mph then we can tell if you should be running quicker times and it's down to traction!
You need to get your 60ft time 2 seconds or below!
If your not hooking DR's will help tell us your 60ft time and mph and then we can see where your at.
WHAT HE SAID (HI ANDY)
I TOOK MY KENNE BELL ZO6 TO THE TRACK FEW WEEKS BACK.
647HP AND GOT NO TRACTION =12.63.
TIRES ,THATS WHAT THEY WILL TELL YOU.
ITS ALL A BIT OF A GAME,COS THEN YOU WILL NEED ALL THE TUFF PARTS FOR YOUR CAR =$$$$$$$$$$$ NITRO UK
Old Jun 24, 2007 | 09:48 AM
Ranger's Avatar
Ranger
There are a lot of small technique adjustments that will help you shed ET tenths.
Suggest reading this page: General Launch Techniques
It takes seat time making passes to get proficient at launching and shifting an M6/M12 Corvette.
Your development of driver skills will progress faster if you start with stock tires and then later go to drag radials.
Ranger
Old Jun 24, 2007 | 11:09 AM
Dave00C5's Avatar
Dave00C5
Those are not bad times for someone new to the track. The trick is to hook up without bogging or smoking the clutch and repeat the technique that works. Once you get the holeshot down the 60' and et will improve to be where you feel the car is running its best times.
Mike Mercury's Avatar
Mike Mercury
What was your 60' times ???
before looking into upgrade equipment... IMO you need to look into improving your launch first. If you haven't mastered a usuable launch yet, then you won't gain much from all those mods mentioned.
A stock C5 (to those Mustang peeps... "stock" means exactly the way it came from the factory) should get 13.5's all day with a marginal driver.
I could get 13.3's all day in my stock (to those Mustang peeps... "stock" means exactly the way it came from the factory) 2002 A4.
Old Jun 24, 2007 | 11:30 AM
myk7's Avatar
myk7
The best 60ft I ever got with stock tires was a 2.05 with no consistancy. With M/T drag radials, the best so far is a 1.88, with consistant 1.95s. It spins a little when I first launch then bogs a little, then goes with no spin. If I could get rid of the bog I believe I could get into the 1.7s consistantly. Best 1/4 mile time is 12.95 on a hot very humid day. On a cool dry day I expect to get into the 12.7s.. maybe better :-)
97 M6
stock engine with 238k miles
LG street long tube headers
LS6 intake
Ti catback
Vararam
Tune
Old Jun 24, 2007 | 06:19 PM
JuicedVette036
my 60ft times were 2.25, 2.34, 2.38. MPH was 101,102,103. I am looking to get some DR's to bring my times down
Old Jun 24, 2007 | 08:52 PM
Mike Mercury
you can try the brute force method with DR's... but with a 2.25 - 2.38 60' times... that points more to technique than to bad tires.
I get consistant 2.0 60' times; on a a good night 1.89 to 1.99 (and that's with the factory GY EMT Run-Flats and a stock motor.
Practice... practice... practce
Old Jun 25, 2007 | 09:12 AM
Ranger's Avatar
Ranger
Just a small point regarding the difference in expectations for an M6/M12 manual tranny and the A4/A6 automatic tranny....
JuicedVette036, the thread starter is driving a manual.
It is true that ET for an A4/A6 is governed heavily by the 60' time. That's because after the 60', the shift points and shift speeds are directed automatically by the car itself.
That's not the case for a manual tranny, where after the 60' the driver must make two or three shifts and shift speed and shift rpm both depend on driver skill and experience.
conceptually, I divide my M6/M12 passes into two increments.
(1) the 60'
(2) the 60'-1320'
There's a lot of individual tasks in the 60' to 1320' segments that can be practiced to reach optimization. In aggregate they have a huge effect on ET. Shift quality, accuracy and speed can become essentially automatic with practice, practice, practice. But shift points require constant attention. And for a new racer making initial passes in a platform or car, none of those elements are optimized. They all need work.
That's the allure of the manual tranny.
Ranger
Old Jun 25, 2007 | 09:28 AM
Secret237's Avatar
Secret237
The mph is there to run low 13's get that 60ft time down to 2 seconds as Mike said. It's the spin you have to eliminate you need to leave the line with as much power as you dare give it with the least wheel spin!
.2-.38 off your 60ft time is worth .4 -.76 of a second off your ET if you are trying to achieve your cars best time it's won and lost in that first 60ft!
What rear tires are you running?
I just did a 13.3 105 mph in my C5 with an auto.
I left the traction control ON because I fugured it could do a better job of launching than I could, I guess it did.
Old Jun 25, 2007 | 10:07 AM
99FRCWhite's Avatar
99FRCWhite
We have been documenting our mods and results of our Velocity Corvette Club project car named VCC-BLU.
You can read about our results here:
http://www.velocitycorvette.com/?cat=2
Old Jun 25, 2007 | 10:33 AM
Ranger's Avatar
Ranger
Makes no difference if your stick shift or Auto on a stock C5 Vette mess up the first 60ft and you have blown your chance of a good time and of coarse if you are stick shift there are more gear changes to mess up!
Well...with an A4/A6, once the 60' is in the bag, the rest of the pass is done without much driver intervention, other than keeping the foot on the floor and the car in the racing groove.
In contrast, post-60' the manual-tranny guy must personally control
(1) shift point for the 1-2
(2) shift correctness and speed for the 1-2
(3) throttle action during and post shift
(4) shift point for the 2-3
(5) shift correctness and speed for the 2-3
(6) throttle action during and post shift
(7) shift point for the 3-4
(8) shift correctness and speed for the 3-4
(9) throttle action during and post shift
Any error or imprecision in any of those nine actions will adversely effect the ET for the pass for the M6/M12 driver. Lot more elements to potentially screw up. That's why it takes seat-time making passes to get the post-60' portion of the pass dialed-in. And it's why the lead-poster will need practice, practice, practice on more than just the 60'.
Ranger
Old Jun 25, 2007 | 10:36 AM
nickolbag's Avatar
nickolbag
Keep in mind Florida air sucks. With summer Florida air I'm sure the conditions were less than ideal. Maybe the track prep sucks too and thats why you were spinning a lot. Your 60's are horrible but will come down with practice. Get them down in the 2.0 range or below and you are easily in the mid to low 13s.
Old Jun 25, 2007 | 10:57 AM
HeadHunter1's Avatar
HeadHunter1
You just made me feel much better I had mine out about three weeks ago. Two different tracks: Union Grove in WI and Memphis Motorsports in TN. Best time in Union Grove was 12.10 and at Memphis it was 12.66 both had about 2 second 60's. I have now ordered the CCW drag pack, but they are backordered.....
Old Jun 25, 2007 | 12:08 PM
chaase's Avatar
chaase
St. Jude Donor '12
Those are really high, with practice you should be able to get into the 2.0xx and even the 1.9's on the run flats.
Old Jun 25, 2007 | 03:47 PM
02gt350's Avatar
02gt350
its not tires, its you. Just need to get some practice man, thats all. Keep at it. And stock C5's are not in the mid 12's . its rare
To Bad track times!!
Old Jun 25, 2007 | 03:55 PM
Ranger's Avatar
Ranger
Yeh I said it was possible to miss a shift!
It still won and lost in the first 60ft the most important part of a drag race is getting the car off the sart line and getting the best possible 60ft time.
Knowing how to change gear should not be a problem for anyone who knows how to drive their car. It's just changing gear!
Spoken from the perspective of an auto-tranny driver....
Driving a 6-speed manual, the difference in gear shifting and shift points between an average driver and an excellent one is between .40 and 1.00 seconds. That's a bit more than a rounding error.
Ranger
Old Jun 25, 2007 | 04:02 PM
chaase's Avatar
chaase
St. Jude Donor '12
Ranger
Listen to this man..All who heed his wisdom have greatly improved their racing abilities, except me (I drive an A4)
Old Jun 25, 2007 | 04:11 PM
B-ras's Avatar
B-ras
He runs 13.67 @ 101 in his A4. What can he possibly have to learn from Ranger about driving an MN6?
