Instrument Cluster Problem
Old Jun 28, 2007 | 10:48 AM
C5 4 ME's Avatar
C5 4 ME
Default Instrument Cluster Problem
My instrument cluster does not light up. Everything else works--all the gauges, headlights, hazard, tailights, and side lights. It's just the instrument cluster. My auto electric guy checked the fuses and they look good. He changed the multifunction switch to correct another problem and I was hoping it would fix this problem also but it didn't. I'm trying to avoid changing out the instrument cluster. Any advice would be appreciated. Thanks in advance.
Old Jun 28, 2007 | 11:00 AM
SilvaDragon's Avatar
SilvaDragon
Have you fiddled with the dimmer switch to see if that's the culprit?
Old Jun 28, 2007 | 11:19 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
During the day, the DIC controller light sensor sends brightness information to the BCM and the BCM then controls the brightness of the instruments. During the night, the Dimmer controls the input to the BCM which again controls the brightness of the instruments.
Old Jun 28, 2007 | 10:18 PM
C5 4 ME's Avatar
C5 4 ME
The dimmer switch on my son's 02 Coupe has a lock setting on it. The one on my 98 Coupe does not lock when pushed in. Could this have anything to do with the instrument cluster not lighting?
To Instrument Cluster Problem
