Startup problem!
Old Jul 1, 2007 | 05:35 PM
ZO6TrailblazerSS's Avatar
ZO6TrailblazerSS
Default Startup problem!
Hey guys, just a question, I went to start my 02 Z up today and it wouldn't start, the speedo/tac/lights all went throught the testing/startup process and then I heard a humming noise but the engine didn't start. Any ideas what could be wrong?
Old Jul 1, 2007 | 05:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You either have a bad Theft Deterrent Relay (TDR),, bad solenoid,,, or a defective starter. I would also check to see if the main power wires and ground wires off the battery to the starter/engine are in good condition, clean and tight.
Mine does the same thing. If I continue to attempt to start the car, it will start. Havnt had time to sit down and mess with it. Guess, I get stranded one day and have to fix it.
BC
Old Jul 1, 2007 | 05:54 PM
ZO6TrailblazerSS
BC
When it started earlier today I got a "Charge System Fault", it went into the dealership before for that when I saw it but they said "all set no prob's" only prob my warranty ended 3 days ago...
To Startup problem!
