LS6 intake swap problems again !!!!!!
Old Jul 1, 2007 | 05:48 PM
123sugey's Avatar
123sugey
Dig
Default LS6 intake swap problems again !!!!!!
PLEASE HELP..........
Next problem
On the drivers side, there is a tube running to the front of the intake. There is 2 T'd things coming off of it ( one towards the front and one towards the back ). They both have electrical connectors going to them. The one in the back has another exit tube ( ?!?!) coming from it.
The piece of tube connected to it right now is only 2 1/2 " long. Where is the rest and where does it go ?
*The main line is fine going to it- just the rear t'd part is the problem
This is why i usually pay people to do my work !!
Old Jul 1, 2007 | 07:01 PM
zeevette's Avatar
zeevette
Next problem
I assume you're talking about the water crossover tubes. You need to get two block off plugs for the rears (where the tubes connect to the heads) and a LS6 crossover for the front, and toss the tubes away. Any electrical lines on the valley cover are for the knock sensors, those black round things on the valley cover. Leave them alone.
Old Jul 1, 2007 | 07:20 PM
123sugey's Avatar
123sugey
Dig
No, the tube is on top of the drivers side valve cover. Running from front to back. The front goes into the drivers side front of the intake ( on the side of the mouth of intake ). The line goes back into a box located on the valve cover then runs more towards the rear and goes into another box. That rear box is the one. The line is for vaccum or something. both boxes have electrical connectors also..
Old Jul 1, 2007 | 08:04 PM
123sugey's Avatar
123sugey
Dig
I think it is called the Evaporator purge line ( bleeds off fuel vapor ).
I cant find the other end towards the back of the motor ..........
Old Jul 1, 2007 | 08:26 PM
123sugey's Avatar
123sugey
Dig
Old Jul 1, 2007 | 08:44 PM
123sugey's Avatar
123sugey
Dig
Here it is.....
Old Jul 2, 2007 | 09:25 AM
123sugey's Avatar
123sugey
Dig
TTT.. still need help here
Old Jul 2, 2007 | 09:46 AM
vettenuts's Avatar
vettenuts
Let me first say I have an 02 so it "may" be different but I did look on my parts CD and the parts between the 02 and the 97 look the same. The EVAP line looks like a snake with ribs from the firewall to the solenoid and the same from the solenoid to the front of the intake. Below is a photo of the solenoid to firewall hose. Two questions, can you get any other photo's as I don't personally recognize that item from the view in your photo. Second, do you know where the hose originally ran on the LS1 intake prior to removal? It could be that someone swapped the original lines for rubber hoses.
Old Jul 2, 2007 | 09:51 AM
vettenuts's Avatar
vettenuts
Found a photo with the connection in it, see the hose in the circle below:
Old Jul 2, 2007 | 10:19 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the correct answer is, nothing, this is a 97/8 ONLY item, I remember this on my old '98
Old Jul 2, 2007 | 11:16 AM
myk7's Avatar
myk7
on my 97, the port closest to the electrical connector is not connected to anything. In the pic with the line circled in red, that one connects to the line that runs to the front of the motor
GreyGT-C's Avatar
GreyGT-C
damn...Steve beat me to it.. That lil elbow hooks to absolutely nothing.... i was looking for a location for it 2 months ago and finally got the right answer.
Old Jul 2, 2007 | 11:21 AM
vettenuts's Avatar
vettenuts
Well, guess that's why I didn't recognize it.
Old Jul 2, 2007 | 12:45 PM
123sugey's Avatar
123sugey
Dig
Wow !! So it connects to nothing ( my pic that i'm pointing at ) ?
So, my ls6 swap only had 128 problems........ not 129 !?!?
Thanks for all the help guys
Old Jul 2, 2007 | 01:03 PM
myk7's Avatar
myk7
right
To LS6 intake swap problems again !!!!!!
