F45 & RTD Simulators
Old Jul 2, 2007 | 05:42 AM
Mikev078's Avatar
Mikev078
Default F45 & RTD Simulators
I just changed out my F45 shocks with some Bilstein Sports. The problem I have run into is that the rear plugs don't match up for the 2-prong simulator caps. The 3-prong caps worked just fine, and both 2 & 3-prong worked fine on the front.
Looking at the factory 2-prong plug where it's supposed to connect to, they seem to be identical male connectors. So, I was unable to connect 2 of the sim caps and this has caused a check gauges message and max speed of 80mph.
The simulator cap kit I got was from CorvetteGarage.com
This is on a 2003 50th Anniversary Coupe. The kit says it's for 1997-2004, but maybe there is a difference that I'm missing. I've seen some F45 setups with 3 choices. Mine only has Sport or Touring.
Old Jul 2, 2007 | 08:55 AM
BlackZ06's Avatar
BlackZ06
If you have a 2003 you have the MSRC (F55) suspension option. F45 was not available in 2003. Cars with F45 have 3 positions for the Ride Control selector ... F55 cars have two positions.
Old Jul 2, 2007 | 10:17 AM
Mikev078's Avatar
Mikev078
Ahh, that would explain the mis-fitting on those last two sensor caps.
Any idea on how I could get the code cleared so it wouldn't trigger anymore?
Old Jul 2, 2007 | 10:37 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP. Just have the F-55 option de-programmed from the BCM! It will have to be done with a GM TECH II. If you get the option removed, you wont need the silly Sims!
Old Jul 2, 2007 | 12:16 PM
Mikev078's Avatar
Mikev078
Anyone have instructions or a link to how to deprogram the F-55 from the BCM using the GM Tech II tool? I called the dealership a moment ago and said they could probably do it, but he didn't seem too sure on how to. So I would like to have the instructions handy just in case.
Thanks!
Old Jul 2, 2007 | 06:37 PM
StingR's Avatar
StingR
Thanks!
You might give Shawn a call at LG motorsports in Wylie. He might give you the info needed. He did mine at LG's today.
Old Jul 2, 2007 | 07:53 PM
LF97C5Vette's Avatar
LF97C5Vette
Search the forum for F45 Delete. There is a write up on it... i had mine done at the dealer w/ a tech II. Took 5 minutes, cost $20... Removed the option from the BCM so it doesn't even look for it anymore... no more codes, no more 80mph limit... C6Z06 shocks for me!
Dan
Old Jul 4, 2007 | 06:06 AM
BlackZ06's Avatar
BlackZ06
Thanks!
Take a look here :
http://www.stopforce.com/RPO.html
Also, be sure the controller is disconnected/removed before you try to delete the option from the BCM. When the car is started, if the BCM sees the controller on the network it will add the option back on.
Old Jul 5, 2007 | 01:36 AM
bdiddo's Avatar
bdiddo
Check this post out
http://forums.corvetteforum.com/show....php?t=1747912
To F45 & RTD Simulators
