Iam in the process of setting up my ride height by measuring the distance between the jacking points and the ground at each corner of the car. My question is this, for best street handling should the ride height be the same on all four corners of the car or should the front be adjusted lower/higher then the rear by some amount ?
Iam trying to setup my ride height but Iam getting some unexpected results. If my shocks were worn out or worn unevenly could this effect my ride height ?
